Hi to this forum. I'm actually quite new to auto mechanics - being only rebuilt a old Jawa sidecar bike before. However, I do have a crazy plan to install a 1.9 TDI to a legendary Lada Niva from '83.
To be more clear on the purpose of this project - not to have any misinterpretation. I really fell in love with the car. The design and the way it's built. Very soviet, robust and simplistic. It's small, compact and it's actually quite good off road for it's time. It features 4 coil springs, a transfer case with central diff lock and a slow/high speed switch.
In short, I really love the cars looks and feel, but I loathe the lada engine and gearbox in it. The engine is only 59kw, which isn't it's problem. The problem is that it does not have any torque before having only few at 3000+ rpm. The gearbox is 4 speed, which means highway speed I am at 3500+ rpm, with extreme LOUDNESS due to the engine, gearbox and transfer case vibrations etc. There is an 5 speed option, but it sucks due to it's poor durability.
So, my logic was, let's put a bomb-proof 1.9 TDI into my Niva with a transmission which will not break down. The 66kw one actually fits perfectly for Estonian law, which is that I can not increase the engine power more then 30%, volume more then 20% and weight more then 10%. There are coupe of issues though.
First and the biggest is the transmission. I don't want to use Lada-s. So I did lot's of searching the forum here to find any options that would be as easy conversions as possible. The best seemed to be the Ford Type 9 transmission, which is very accessible here in Europe (Estonia) in a Ford Sierra for example. I almost bought the bellhousing kit - but then did some last minute measurements. It does not fit due to it's length. Even if I move the engine more font it does not fit. The reason is that the Niva has a separate transfer case behind the transmission. The total length for the transmission therefor is maximum 63 cm (25 inch)
So basically I need a RWD transmission which is quite short. BMW came to mind. I could do a transfer plate. But, BMW has the starter on the drivers side - no room for that on the 1.9 TDI. I've also come by the Toyota W58, which measurements I do not know but it looks too long on a picture at least.
So, this is the reason why I'm making my post here. To ask help from much more experienced TDI-ers. I appreciate any ideas how to make the build happen or any hints which transmission to use.
And by the way, this is my orange Niva:
cheers!
cheers!
