diesel sammy
I changed the radiator and both upper and lower radiator hoses as well as the thermostat and lower housing.
I put it all back together and added coolant to the resovoir as the vehicle was running.
I turned on the heater.
As the vehicle started to pressurize it started to leak around the radiator cap.
I took the cap off and the coolant started to surge.
It would suck down in the radiator and then surge out of the radiator.
The temp stayed at about 180 degress.
Anybody have a idea of what wrong?
I also noticed the upper hose got hot while the lower did not.
