Any VW Modders in Saskatchewan?
Trcoelho
Saskatoon
Jetta MK4
Just looking to make connections with any local VW owners.
I'm in Saskatoon.
I have a modified 2000tdi jetta (VNT17, PP764's, 11mm IP, 2.5" straight pipe, etc).
Currently working on a number of upgrades (PD150 intake, EGT and Boost gauges, etc).
Recently installed a 0.681 5th gear and stage 2 southbend clutch which works nice.
Does anyone have a VAGCOM in the area?
Nuje
Island near Vancouver
There's someone in Saskatoon fairly active on here; FreezinSask or something like that is his username.
TDIMeister
Canada
TDIsyncro hops between Saskatoon and Prince Albert IIRC when he's not working in the far north.
flatlanded
Saskatchewan
2002 Jetta
I have an 02 in Regina. 17/22, PP520s, tune, clutch, etc. It's starting to wear out however so I'm looking at the '15's and wondering what makes them worth $40k.
I have the older VCDS for your '00 as well. Waiting for the wifi version to be released in Canada before I upgrade.
Trcoelho
Saskatoon
Jetta MK4
If your willing to sell or lend out your VCDS, let me know.
I just installed the larger nozzles and want to check fueling.
Just picked up a 3" EGT probe.
Wondering if I should remove the turbo and install in front of the exhaust impeller, or would I reach far enough down to get a decent reading from the egr.
