richard_gomm
Hi all,
I've had a number of problems with my car recently, slowly getting them fixed with help from various forums.
The car:
Passat, B5, 130 BHP 1.9 TDI. 2002 year AWX engine code.
History:
Replaced wastegate, all vacuum tubes, oil, oil filter, fuel filter, injector, injector wiring loom, glow plugs.
Problem:
When starting from cold the car chuck out a large amount fo water smoke. Smells strongly of diesel (not oil)
Vag com has the following:
17569 - Manifold Temp Sensor (G72): Open or Short to Plus
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
Could these cause a huge cloud of white smoke being produced? Is it just one unit? Can it be changed / swapped easily (locaion in car if known please)
thanks everyone
Richard
The car:
History:
Problem:
thanks everyone
Richard
