Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old September 12th, 2019, 20:18   #76
Lightflyer1
Lightflyer1's Avatar
I would think it quits regen but takes some time to cool down just sitting there. The real test is to see if it starts back up again soon after interrupting it like that. Like with VCDS or VagDpf.
Old September 12th, 2019, 20:32   #77
bigb
I have shut down during a regen and restarted right away, the regen continued where it left off. Once I shut down just as it started and went inside for the night. Next day the regen started over as soon as operating temp was reached. I have been able to get my regens down to 12 minutes in town. I keep the rpms between 1,500 and 2,000, if I hit a red light I pop it into neutral and hold the brake and nudge the accelerator with my right foot (I have size 16D feet) to keep it at 1,500. The soot load continues to tick down just as if I were moving. 12 minutes she finishes and a couple more minutes for the EGTs to cool down to normal. All verified with VAG-DPF.
Brian...
bigb is offline   Reply With Quote
Old September 13th, 2019, 06:08   #78
Lightflyer1
The question is though will it complete just sitting in a parking lot at idle? I think not.
Old September 13th, 2019, 06:29   #79
jmodge
Does the software allow a forced regen like trucks do, raising the idle and monitoring egt’s and pressure differential?
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old September 13th, 2019, 06:48   #80
bigb
Yes, a standing regen can be initiated by VAG capable diagnostic software. OBDeleven will do it.
Brian...
Old September 13th, 2019, 06:49   #81
bigb
Shall I be the guinea pig?
Brian...
Old September 13th, 2019, 08:03   #82
Lightflyer1
The software in the car does not allow you to initiate a forced regen on demand. If you have the factory tool or VCDS or similar then yes you can do it. Not something you would want to carry around and hook up and do in the parking lot though. It would be easier and faster to just keep driving for 10 minutes or less.
Old September 14th, 2019, 08:52   #83
Diesl
Default Regeneration DOES finish at idle!
Regenerations most definitely continue at idle on my 2012 TDI Sportwagen. It's easy to observe if you monitor the exhaust gas temperatures.
If it works, take it apart and find out why!
Diesl is offline   Reply With Quote
Old September 14th, 2019, 10:38   #84
jmodge
Probably injects diesel fuel upstream of the dot. Unless you inject def. trucks would do the same, ecu watches egt’s and controls injection
Old September 14th, 2019, 19:24   #85
Diesl
The TDI does late fuel injections in the cylinder; this is all known and has been discussed here.
An advantage of idle regenerations is that the turbo temperature is lower, at least from what I am seeing.
Old September 20th, 2019, 19:52   #86
theaterlightman
My tdi is experiencing low fuel economy, 32 mpg in the past ive gotten 40mpg with a 2 bar map and vnt17 turbo.
Ive gotten a check engine light with intermittent excess fuel in the exhost and when i looked at my egr it was gunked up so i cleaned it. I was wondering if my problem a dirty intake or bad fuel injectors. Listed below will be my readings.
theaterlightman is offline   Reply With Quote
Old September 20th, 2019, 19:59   #87
theaterlightman
Default Poor fuel economy
Mas air flow 300 mg/str
Boost pressure 1020 actual and specified
Ingection
Cyl 1 -.75
Cyl 2 -1.25
Cyl 3 2.87
Cyl 4 -.85
Fuel consumption 1.8 l/h
All above is at idle
O2 sensor 3.69 at idle and 16 when cruising at 45 mpg
Fuel economy of Dieselgate TDIs removed from EPA's fuel economy website and datafiles Max Period Dieselgate - VW Group Emission Scandal 0 October 28th, 2016 21:24
Page generated in 0.15388 seconds with 10 queries
[Output: 110.09 Kb. compressed to 92.83 Kb. by saving 17.26 Kb. (15.68%)]
