Old June 25th, 2019, 19:53   #1576
JeffsSportWagen
JeffsSportWagen's Avatar
Finally made some progress on my DIY GTD conversion. Got the bumper with all the trimmings from Ebay, just needed a new mesh grill and the holes for the previous owner's California front license plate filled. Did all prep & paint work myself. (I do all my own stunts)
I still need to wire up the fogs and I have a GTD grill badge on order from E-Acca so still a bit more to do here but I'm happy with it.
GTI, R, Clubsport and Alltrack bumpers are basic swaps within our Mk. (Mk7 to Mk7 only)
2015 GSW S TDI/dsg, Night Blue/Shetland Gray
"I have a car-sickness. I need to be checked into the HENRY Ford Clinic." -Tim "The Tool Man" Taylor
JeffsSportWagen is offline   Reply With Quote
Old July 2nd, 2019, 14:05   #1577
jason_
Mounted some new summer 16s.
I was going to balance them, but this time I'm trying the steel shot trick....
I put 10oz in each tire. See what happens.
Sent from my 2PS64 using Tapatalk
jason_ is offline   Reply With Quote
Old July 2nd, 2019, 16:14   #1578
thundershorts
Forget that trick, it will not do anything but really screw up balance.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old July 5th, 2019, 14:48   #1579
thundershorts
If you've ever gotten water in a tire you will know what I mean.
Old July 5th, 2019, 20:38   #1580
Discovery
Airlift bag in a H&R spring. Pretty sure I'm the first one to do that.
Now it sit the same with or without trailer.
Discovery is offline   Reply With Quote
Old July 6th, 2019, 14:57   #1581
Nuje
Got a part/model number on that airbag lift?
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, DSG tune
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is offline   Reply With Quote
Old July 6th, 2019, 17:17   #1582
jason_
I run loaded tires on the 3500 srw. I occasionally hit the road and get fuel.
Never notice any difference.
Old July 8th, 2019, 11:27   #1583
Discovery
This is the airlift 80753, it is perfect for stock height spring.
But, if I was to do it again I would use the airlift 80777 which is 1,75 inch shorter.
Because I'm running lower than stock (H&R) spring, I ended up not using the supplied "spacer/protector" in order for them to fit in.
Time will tell if its going to affect their durability.
Old July 9th, 2019, 04:23   #1584
740GLE
I've heard they need a minimum PSI otherwise they'll develop a tear along the body of them, keep an eye on them.
How are you routing the filling port/valve? I've been toying with the idea of placing mine by the fuel filler door.
Old July 9th, 2019, 06:58   #1585
Discovery
Yeah, I heard that... Pretty much impossible to remove them without damaging the bag. If/when they fail I'll install the shorter kit.
Valve are under the bumper, pretty much invisible without kneeling.
Old July 9th, 2019, 07:13   #1586
ProfBrown
Fuel Economy: In the sig
This above looks really clean man. Nice! If I have the need to put a hitch on mine I’ll do this for sure for the trailer lights.
2015 GSW TDI SE DSG
DON'T TRACK THIS ANYMORE
ProfBrown is online now   Reply With Quote
Old July 9th, 2019, 09:00   #1587
740GLE
whoa, you went with two valves and not a T so each bag are even? you going to fine tune each bag depending if there is a passenger or not?
very nice install, did you have to pull the bumper cover off to mount those?
Old July 9th, 2019, 13:01   #1588
Discovery
No removal needed.
It's not really for fine tuning, it's to find out quickly which one is leaking!
Old July 9th, 2019, 17:00   #1589
Nuje
No removal needed? So, you can just reach into the centre cavity and route the air lines from there (?).
Or do you just mean that the bottom valance comes off separately / cleanly?
Old July 9th, 2019, 17:02   #1590
Nuje
Driving home the other night (clear, perfect summer evening), suddenly I get a warning message that "FRONT ASSIST SENSOR BLOCKED"
Only ever seen this before in the winter when snow/slush builds up on it.
Get home and...
[Insert Batmobile joke here]
New mk7 features not highlighted. 03_01_TDI VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 45 October 16th, 2015 18:37
Took a Mk7 GTI for a drive today... Nuje VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 1 July 23rd, 2014 13:51
Golf Mk7 Tfinn VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 11 August 29th, 2013 09:02
MK7 2014 Golf elitegunslinger VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 29 September 10th, 2012 10:55
Page generated in 0.18255 seconds with 11 queries
[Output: 128.20 Kb. compressed to 107.11 Kb. by saving 21.08 Kb. (16.45%)]
