Digilio86
Can some point me to a thread that shows how this is done? Doing dsg service and can't seem to figure it out.
Sent from my SCH-I545 using Tapatalk
The only way to delete a thread is to ask a moderator. Send a PM to a moderator. A "regular" member does not have the permissions necessary to delete a thread.Urr figured it out. How to delete thread is the question now.
In most cases members can delete their own posts. The exception to that rule is deleting the first post in a thread (the beginning of the thread). Only a moderator or administrator can delete a complete thread. Whether or not this is a good idea or not - I do not know. It is the way the forum software is written or configured.DUMB... not having delete capabilities
Thanks for following through with this thread. I also had difficulty trying to figure it out until I read this. Thought I had reached a dead end on it until I read the reply'sYou are right OilBurningBrit..Well it was really quite easy you remove all the plumbing so you can detach the air box. My issue was once all the obvious screws and attachments where removed the box still wouldn't budge. The air box is also held in place much like our engine cover so a firm pull upwards is needed. No biggy just maybe not obvious to someone that hadn't done this before and that isn't trying to break anything.
I would be happy to delete this thread, if/when the OP requests that it be deleted. Personally, as I see it, the OP posed a question, figured out the answer himself, and then shared what he learned. After a few hesitations, useful information was revealed. Delete you post if you want to, but I won't delete the whole thread unless the person who started it makes the request either here or by PM.Tomorrow maybe I'll delete this post I'm making now! That is if this entire thread isn't deleted by the moderator.
The only waste of internet in this thread and other threads are the responses that are not related to the original question, either clarifying the problem or providing an answer to that problem.Waste of internet here.... Move along....
