OakHillVariant
For you folks who have been replacing your springs on the Passat NMS, where are you placing your jackstands?
Rennstand by Safe Jack https://www.amazon.com/dp/B07JL8XP5Q/ref=cm_sw_r_cp_apa_i_RoxxDbZTJXYTY
I use these on my Golf and Jetta wagon. Not cheap but work well and made in the USA.
The universal pinch weld adapter that comes with it. I wish it was deeper but it works. They sell VW adapters but those are for the optional lift pads used with commercial lifts. I've heard that those can be "iffy" if you don't lift all 4 simultaneously so that's why I'm using the pinch welds.What adapter are you using?
