FlashandFlare
- Joined
- Jun 10, 2005
- Location
- Princeton, Wisconsin
- TDI
- 03,Jetta GLS Reflex on Blk leather, 06 Jetta Blk on Blk Pkg 2
I have 2 pods, these are the upholstered style to match your cars interior, there also stackable.
They come from a SMOKE FREE home.
Molded from ABS plastic and professionally upholstered, our A-pillar gauge pods are perfect for holding a single gauge. Unlike the typical A-pillar pod, our pod is designed to be positioned at the lowest point possible without blocking the defrost vent. Our pod fits 2 1/16” (52mm) gauges of any type. The pod is large enough to accommodate mounting brackets, wire and tubing with ease. A built in wire trail is used to cleanly route wires and tubing below the dashboard
Installation is solid and simple. Designed to wrap securely around the A-pillar, tabs of excess fabric extend from 3 mounting points. Use contact cement, hot glue, Velcro®, or tape to attach the mounting tabs to the back of the stock A-pillar. This product requires no permanent modification and leaves the A-pillar in original condition.
There $75 a piece retail
I will sell both of mine for $100obo
I will ship world wide.
These have never been installed.
