I will be changing the front left abs sensor on my 2005.5 mkv tdi (BRM). I'm not sure what the head of the bolt looks like but I will be able to tell you next week (after I replace mine).
The original OEM 7H0927803 has been replaced by OEM WHT003857. I ordered the Ate ES#:9547 from ECS Tuning
http://www.ecstuning.com/Volkswagen-Jetta_V--TDI/Braking/ABS/
and for $0.99 more I ordered a replacement bolt. They also had the OEM but Ate cost $37.41 OEM cost $95.07 and dealer charges $155.82 just for the part (didn't ask what install would have been).
Tools: deep 17mm socket to remove lug bolts and what ever the sensor bolt ends up being...
I'm not sure how to add a pdf to my post otherwise i would attach procedure.
1. Raise your car
2. Remove wheel
3. Separate speed sensor and speed sensor wiring connector
4. remove bolt that attaches sensor to wheel bearing housing
5. remove old sensor and clean out the hole
6. coat new sensor with hot bolt paste
7. insert new sensor and tighten bolt to 8 Nm
