Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old March 8th, 2017, 10:45   #1
diesel#2
Default turning soot into ink -- solution to dieselgate?
http://www.graviky.com/kaalink.html
​Kaalink™ is a unit used to capture soot, which is then processed into making Air-Ink. The unit captures 95% of the particular matter pollution without inducing back-pressure. Kaalink is presently under certification and commercial pilots, and available for private demonstrations. The unit works hard to capture outgoing pollutants, and is designed with heat and water-proof electronics and materials.
how do i get one!!!
diesel#2 is offline   Reply With Quote
Old March 9th, 2017, 08:31   #2
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
No back-pressure, and it captures 95% of particulates. Sounds impossible.
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old March 13th, 2017, 12:16   #3
> Luke <
I'll 2nd that; I'm tending to think along the same line.
As of 8/6/2018: Latest 10 Fill-up Moving Average = 49.4 MPG. at 323,239 miles. Zero Oil usage. Only Chevron Fuel. I also carry a 6 gallon reserve container, used weekly: Thus allowing me to fill every Sunday. Latest fuel use average from purchase date = 50.7 MPG & still Very happy with my vehicle.
> Luke < is offline   Reply With Quote
Ink removal from visor lildevildee TDI 101 11 January 2nd, 2006 14:53
Ink removal from visor lildevildee TDI 101 1 December 30th, 2005 08:19
Hybrids get the ink, are diesels better? Oberkanone TDI News/Tech 43 July 27th, 2004 17:41
ink stain on seat bmike General VW Discussion 6 November 26th, 2002 20:07
Soot? / accelerator turning knob? / correct ride hight? feto VW MKIV-A4 TDIs (VE and PD) 4 October 21st, 2000 20:01
Page generated in 0.11977 seconds with 11 queries
[Output: 57.96 Kb. compressed to 52.62 Kb. by saving 5.34 Kb. (9.22%)]
