BT3076
Whats up guys,
My brother has been having issues with his dpf and doing a regen. Looked at channel 241 for the calculated/ measured soot and they are 45.1 and 43.8 respectively. I understand if one of the values are above 95% (45gms) then an emergency regen can not be allowed. I have read on here how guys have reset their values somehow through vacgom and then did a regen and it seemed to fix the issue. Any insight on this? There is also soot in the tailpipe so I'm not sure if the dpf is cracked or what not. Original plan was to remove the dpf and replace it with a downpipe and get the assiciated software from malone and just be done with it. But this fix has us second guessing that. Any suggestions on what to do in this situation?
thanks,
Chad
thanks,
Chad
