Old October 21st, 2018, 13:54   #16
eddieleephd
Fuel Economy: 38mix / 47@70-75
Originally Posted by rohls View Post
You guys are great; thank you!
Yes, definitely going to go through the injectors and clean them...see how bad they are. Chances are I'll replace them soon, BUT I'd like to see if this car is going to run at all before I put more and more $$ into 'er.
I was thinking something along the lines of ultrasonic bath with some warmed-up rust remover as solvent...? Then test them..I'm pretty sure my Grandpa has a injector tester.
Do a compression test first then and check the condition of the rings, head, and block. That will tell you more about if it will run quicker than anything!
You're looking for 500psi compression. Drop a table spoon of engine oil in the cylinder and hook up your compression tester. If it hits 500 psi or close it'll run no problem once all the other kinks in the fuel are worked out. Otherwise you're looking at engine work.
Go with the injectors you want, there's no reason that if tuned properly that .205 injectors and an 11mm pump won't pass inspections so long as it's running well and warmed up when you go in for the test.
I wouldn't jump into much more than cleaning the injector bodies. the nozzles need to be cleaned with sonic cleaning and if you try to use tools you will destroy their ability to perform and likely cause catastrophic damage to the engine! Which I see you have done...
Injectors are all cleaned up with the ultrasonic cleaner: look great. I even bench tested them with a proper injector tester.
Thanks for the help.
It's highly recommended to have your injectors professionally cleaned and setup so that they flow properly and within certain parameters so they don't cause holes in the block or piston heads.
At minimum you should perform a pop test to ensure that the initial injection occurs at the correct pressure. If this is not done you truly risk the loss of your engine and a fun project might just be lost.
If you want to have this project for a while take the time to search around and look at all the how to's available in the tdi 101 section and the search engine which is a tremendous resource that utilizes all the best VW specific forums for the answer to your question.
Do not go cheap unless you want it to fail and cost more in the end! Buy quality and respected reputable brands at good prices anywhere, but especially check out the vendor section for deals from the forums trusted vendors.
2002 1.8t Jetta Wagon swapped to Alh w/5spd swap, Vr6 brakes, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, BMW Cyclonic CCV filter, 2" lift, Panzer
Often the best way to find your answer is to use TDI Custom Search
How to make terminal release tools for VW and Audi - YouTube
eddieleephd is offline   Reply With Quote
Old October 21st, 2018, 17:12   #17
jmodge
Why do you recommend a wet compression test?
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old Today, 07:19   #18
eddieleephd
If it's been a while since it's run there's no lubricant on the cylinder wall. This causes the compression test to be off and not true.
Old Today, 07:23   #19
jmodge
Gotcha, probably wouldn't hurt to roll it over several times to disperse it and blow out the extra then?
11MM Injection Pump + Auto Injectors 169K racerxtdi Private TDI Items for Sale/Wanted 7 June 5th, 2018 04:29
FS 11mm MTDI injection pump built by Giles with injectors .205 nozzles. 2200.00 elderair Private TDI Items for Sale/Wanted 3 March 4th, 2018 18:52
Anyone have a N146 Pump Voltage Map for 11mm pump and .184 injectors? Best Estimates? benhart16 TDI Power Enhancements 4 December 23rd, 2015 21:37
FS: 11mm Injection Pump and Injectors Bigman095 Private TDI Items for Sale/Wanted 12 June 20th, 2012 07:25
.184 injectors - 10mm injection pump - 99NB 5spd BlueflameSP Private TDI Items for Sale/Wanted 3 April 18th, 2002 11:02
Page generated in 0.13439 seconds with 12 queries
[Output: 70.07 Kb. compressed to 62.88 Kb. by saving 7.19 Kb. (10.26%)]
