Old October 11th, 2018, 11:07   #1
shane90
TDI(s): passat
Default zf 6hp19
has anybody switched there transmission zf 5 hp19 for the zf 6hp19 ?
shane90 is offline   Reply With Quote
Old October 11th, 2018, 12:53   #2
oilhammer's Avatar
Fuel Economy: fantastic
From what?
The VAG version of the 6sp longitudinal FWD ZF slushbox was I believe only found in AWD models, so it is actually a ZF 6HP19A, and it is a very different transmission than the 5HP19FL units in the B5 Passat. It would be a massive undertaking, with very little if any payoff. The BHW has as much torque as some V8s. It doesn't really need any more gears. At 80 it is square in the meaty part of the engine's output.... halfway between peak torque and peak horsepower. Delivers good fuel economy, never needs to downshift, etc.
www.cardocautomotive.com
Old October 12th, 2018, 04:13   #3
shane90
TDI(s): passat
well one the car i bought the tranny is b/o, so he was going to convert it to the zf 6hp19 all wheel drive or keep it front wheel drive by remvoing the back cover from the zf 5hp19 and installing it on the 6. apparenlty giving 4 liters to 100 instead of 5. so i have this transmission zf 6 and it looks identical to the zf 5 except the rear wheel drive option. amd i want to use if i can. so if any ones do this, can you help
Old October 16th, 2018, 20:17   #4
shane90
TDI(s): passat
Anybody?
ZF Tiptronic 011coach TDI Power Enhancements 7 October 7th, 2016 12:22
TDI mated to ZF 4HP22? NM_Mogman TDI Conversions 14 May 22nd, 2015 16:33
Can this ZF be saved? B4Ugo VW B5 Passat TDIs 14 May 12th, 2015 09:18
ZF or TRW rack? passat man VW MKIII-A3/B4 TDIs 5 August 29th, 2009 17:53
ZF 5HP19 rebuild info vw4life VW B5 Passat TDIs 3 July 17th, 2009 09:38
Page generated in 0.10734 seconds with 12 queries
[Output: 62.06 Kb. compressed to 55.57 Kb. by saving 6.50 Kb. (10.47%)]
