Old February 8th, 2017, 06:15   #46
sardo_67
TDI(s): 2003 Jetta
Fuel Economy: 38mpg (driving like i stole it)
Originally Posted by r11 View Post
We keep forgetting that there's no "fix". There's a 90% band-aid, that brings the cars to pollute at may be 2-3x rate of by-the-book-EPA-book numbers.
There's, of course, the question of whether those EPA-mandated Nox were ever realistic to begin with
that there is the real issue, not VW.
sardo_67 is offline   Reply With Quote
Old February 8th, 2017, 06:19   #47
sardo_67
TDI(s): 2003 Jetta
Not sure there's any new info here. I heard months ago that Gen 1 cars would be fixed with new exhaust components and a re-flash, no Adblue addition. And that Gen 2 and 3 cars would require more extensive fixes, the first phase of which is a software flash. Those are already taking place on the Gen 3 cars. They will get hardware, however, in the second phase of the fix.
The big news will be when the EPA approves the fixes for Gen 1 and 2 cars.
And I've given up on getting a leftover '15. Latest I heard is that they'll have to have both stages of the fix before they're offered for sale. That could be the better part of a year away from now.
I see a lot of 15s on autotrader, although they are asking 32,000 for a 2015 nav jetta...........
Old February 8th, 2017, 06:20   #48
Try and buy one. You won't be able to.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old February 8th, 2017, 06:23   #49
mishkaya
You are correct. I have tried on more than one occasion, only to be told they are not yet available for sale...
'06 Jetta 5MT, '14 JSW 6MT, '10 JSW 6MT
mishkaya is online now   Reply With Quote
Old February 8th, 2017, 06:23   #50
sardo_67
TDI(s): 2003 Jetta
they say they are fixed. I'm not arguing just saying what I've seen.
or in the fine print somewhere they have the stipulation that it's only a deposit and cant buy until more **** is fixed on it?
Old February 8th, 2017, 06:27   #51
sardo_67
TDI(s): 2003 Jetta
also what years are what generation? I saw someone post a 2012 6MT with some very nice mods that I kinda want to buy, I am doing some research into what my possible options would be since it has a full aftermarket turbo back exhaust
Old February 8th, 2017, 07:21   #52
DanB36
MY2015 is Gen3. MY 2014- Passats are Gen2. MY 2014- everything else is Gen1.
"DanB36 seems to be always on point." - CT_White_SRT
Sold: 2000 Jetta GLS TDI, Atlantic Blue, 270k miles
Sold to Dieselgate: 2 x 2013 JSW DSG, 1 x 2013 Jetta Sedan DSG
DanB36 is offline   Reply With Quote
Old February 8th, 2017, 07:28   #53
compu_85
Gadget Guy
compu_85's Avatar
No, that's incorrect. 15s are Gen 3. Passats 12-14 are Gen 2. Other cars 9-14 are Gen 1.
Old February 8th, 2017, 07:45   #54
DanB36
Well, what I meant was correct, but my notation wasn't very sensible. Read "MY 2014-" as "model year 2014 minus", with the assumption that everyone knows we're dealing with only CR 2-liter TDIs, and you'd have my meaning. Your statement is much clearer.
Old February 8th, 2017, 08:01   #55
M_R
FYI our local Toronto dealers are willing to put your name on a 2015 tdi with a refundable $500 deposit, however delivery won't be until first quater 2018 once the hardware fix has been done, and perhaps longer as all the 2015 that are in service right now will need to be done before new VW inventory gets touched.
M_R is offline   Reply With Quote
Old February 8th, 2017, 12:49   #56
Rhino1829
If it's a full turbo back, then it's for sure deleted of at least the dpf and cats. I'm in a similar boat being deleted, and have several "what if" scenarios running through my head. If it's running the cr140 or 170 turbo the OE emissions components should just bolt up. Get those bits put on, retune, and go to the dealer for the fix...simple solution there. My concern is rolling up with a gtb series turbo and how the dealer would react, let alone what they'd do, or not do.
I'm in for the fix but am planning on holding out to see what some of the other guys/gals who are modded end up experiencing and make my plan from there.
Rhino1829 is offline   Reply With Quote
Old February 8th, 2017, 13:24   #57
ecode
TDI(s): Mk6 Wagon
The Canadian deal addresses this - essentially if the dealer needs to add back the OEM tune, or hardware, in order to then do the fix, the owner is on the hook for that cost.
Seems like the Canadian VW team learned from the US settlement...
ecode is offline   Reply With Quote
Old February 8th, 2017, 13:32   #58
Rico567
I can't see how it'll be much different. The mechanical portion of the "fix" will consist of a kit of parts, from what I understand. If that kit won't just bolt in place of whatever is there on a stock car, I'm guessing it's down tools at that point, and the owner is going to have to start spending money.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old February 8th, 2017, 14:01   #59
BleachedBora
BleachedBora's Avatar
Correct - as long as:
a) There is no check engine light for emissions related problems when you bring it in for the work to be done
and
b) Whatever the dealer takes out can be replaced using
1) the provided parts in the kit
2) no extra additional parts
Then you have nothing to worry about.
If the modifications take longer than 3 hours then the dealer is required to provide you with a loaner car.
If the work is completed and there is a check engine light (for example if you have an EGR delete and had it tuned out) then the dealer is required to halt all work until they can get on the line with VW tech to figure out what the problem is and if it's something that they have to fix. Any non-approved modifications that will need to be fixed to bring the car back into compliance will be billed to the customer.
-BB
BleachedBora is offline   Reply With Quote
Old February 8th, 2017, 16:48   #60
cecaumenus
In light of the information about the Gen 1 fix provided at the beginning of this thread, I assume that recent articles in the press with statements such as the following are misguided:
About 325,000 older VW TDI models do not have SCR—and many analysts have expressed skepticism about whether they can be modified to meet emissions standards at all.
An SCR system includes a considerable amount of hardware, so adding it to a car would likely be complex and expensive.
http://www.csmonitor.com/Business/In...ose-that-can-t
cecaumenus is offline   Reply With Quote
Req'd fix for Gen 1 r11 Dieselgate - VW Group Emission Scandal 27 August 18th, 2017 20:32
Req'd fix for Gen 2 r11 Dieselgate - VW Group Emission Scandal 24 June 16th, 2017 05:57
So, will there be a Gen 3 fix? Tri0de Dieselgate - VW Group Emission Scandal 14 July 22nd, 2016 13:12
Req'd fix for Gen 3 r11 Dieselgate - VW Group Emission Scandal 3 July 13th, 2016 14:28
6th gen and 5th gen production. bignik TDI 101 1 August 25th, 2009 21:52
Page generated in 0.19267 seconds with 11 queries
[Output: 132.36 Kb. compressed to 111.61 Kb. by saving 20.75 Kb. (15.68%)]
