2005 PD BEW 350,000+ kms
Running fine when the oil light came on. Instantly lost power and stalled 30 seconds later. Grinding sound from turbo area after briefly re-starting attempt. Towed it home. Removed oil pan which showed a ton of sludge. No visible metal shavings inside oil pan area and nothing loose inside and around the crankshaft that I could see/feel. I'm assuming the oil pickup plugged up which caused the lack of oil circulating to turn into sludge but I'm open to any else's opinion.
To be safe I'm going to get an oil pump delete kit instead of just cleaning the oil pickup. To remove the sludge from the crankshaft area is there a specific lubricant that someone can recommend? Is there anything else I should be checking and/or doing?
