kmak
I have a 1998 jetta tdi and replaced the ignition switch. The switch would not work with a hot cabin temperature. The switch did not fix it . I traced everything down and I have an open circuit between the switch and the starter.
Does anyone have any idea where to start looking? The connection at the starter is good because I can jump the starter to make it work.
