Uswapedtdi
I have a 2012 Volkswagen Jetta TDI automatic but I bought with a blown engine swapped in the new engine only has 40,000 miles on it on the way I can get it to run was by bypassing/(wired in my own relayfor power} the fuel pump that's right next to the injection pump I wasn't getting any power there or I request to turn it on I've looked and searched cannot find the specific relay for the fuel pump I know where the relays are at under the hood and under the dash I don't know specifically which one the fuel pump relay is I've also noticed that the AC compressor is only getting 8 volts. Other issues I have or old saying fuel pump circuit open control pressure circuit fuel temperature and secondary coolant sensor High. Somebody can point me in the right direction for the relays I could at least start with that. I also didn't know if this system has a control module for the specific function of the fueling or AC. Any help on the wiring diagrams relays were specifically to Jews would be greatly appreciated
