oilcanner76
I have a 2004 1.9 TDI Beetle, 5spd manual. My daughter bought it a couple of weeks ago. I drove it home, 135 miles, with no issues except for an abnormal brake pedal. The brake booster tube had cracked. I replaced it and problem solved. It was performing well enough that we decided to take it on a kayaking trip, 235 miles from home. The car performed well until we stopped about 25 miles from our destination. We stopped a a gas station. I turned the car off and went inside for about 5 minutes. When I came back out and started the car, I noticed that the AC wasn't blowing cold. It was 95 degrees so I figured that once I got back on the road it would be ok. I pulled onto the highway and had absolutely no boost and the CEL was on with the P0652 code stored. (Low reference voltage on B circuit) Being at a primitive campsite with limited cell service, I wasn't able to do much research. Car is home, now, and I've begun to try and diagnose the issue. Here's what I've done so far, with no positive results.
1. Pulled vacuum on the turbo actuator to test it. It has full travel and holds vacuum.
2. Checked vacuum to the N75. 25HG. I cannot get any vacuum on the outlet side. I'm not sure if I'm doing it right. I connected the gauge to the outlet side and it reads a constant 0. Even when I rev the engine to about 3500rpm. No movement. I wonder if the code is keeping the N75 from activating?
3. Checked MAP for contamination. I also checked the reference voltage and it is 4.97. I'm not sure if that is low enough to throw the code.
4. I removed and cleaned the wiring harness connections to the ECM.
5. I unplugged the MAF and it didn't change anything.
I'm not sure which direction to go next. I know that whatever set the code is causing the issue. I'm just not real sure on what to check to find the issue.
