The following is the description of the New Beetle
_______________________________________
1999 New Beetle - TDI
230,000 kms (143,000 miles)
1.9 ALH TDI
5 Speed Manual Transmission
Silver
Canadian Car, Vancouver Area (minimal salt exposure) (2nd Owner)
Upgrades/Modifications
Exterior
- Newer side mirrors off 2003 Beetle (Black)
- Euro Style LED’s Headlights (LED Running Lights)
- Front Diffusers (Black)
- Rear Hatch Spoiler (Black) (For Improved Fuel Economy)
- Aluminum Skid Plate
- Integrated Trailer Hitch 2” Receiver(Class 2)
- Comes with 2” Hitch and Ball
- 7 Pin Trailer Wiring Connector
- Factory Cross Bar Roof Rack (With Key)
Interior
- Alpine IPOD Deck
- Alpine Amp and Type S Speakers Front and Rear (Components up front).
- Alpine Type R Sub and Amp.
- Fresh Grey Leather Front Heated Seats (Sat on a shelf for 15 years)
- 2 Pod Gauges (Autometer Digital Boost and Temp)
- 3 Pod Cluster Included (Autometer)
- MK5 GLI Steering wheel (one of the best upgrades)
- (Lots of extra interior parts included)
Engine
- VF Engineering Red Poly Mounts and Dogbone Mount (80 durometer stiffness)
- VNT 17 Turbo
- 1019 DLC Calibrated Injectors
- Colt Stage 2 Cam and Fresh Lifters
- ARP Head Studs
- Large Custom SMIC (HPA Motorsports)
- Large Pancake Pipe (HPA Motorsports)
- EGR Delete with DG Racepipe
- 2.5” Custom Stainless Steel Exhaust Straight Pipe Turbo Back.
- 3 BAR MAP Sensor
- Currently Running 10mm IP and comes with an 11mm IP (Spare)
- B&M Short Shift Kit
- South Bend Stage 2 Endurance Clutch
- Malone Stage 4 Tune with Dynamic Idle
- Fresh Bosch Alternator
- Fresh Interstate Battery
- Timing Belt Kit with Metal Water Pump (~223,000 kms)
Dyno’d at 160 HP and 314 Torque (on a “conservative” dyno) (Stock numbers were 90 HP and 150 Torque)
Suspension
- 25mm Neuspeed Swaybars (Front and Rear)
- KW V2 Front Suspension (Adjustable Coilovers For Height and Bounce Adjustable Shocks)
- KW V2 Rear Suspension (Adjustable Coilovers for Height) (Upgraded shocks to V3 to control rebound and bounce with the trailer)
- Solid Control Arm Bushings (Audi TT) (tightens up the front suspension)
- Fresh Strut Bushings during Suspension Upgrade
Brakes (Cost ~$6,000 USD)
- Front 355mm 2 piece rotors (6 Piston HPA Callipers - Blue)
- Rear 335mm 2 piece rotors with integrated E-brake (4 Piston HPA Callipers - Blue)
- Upgraded front spindles from VR6 Car
- Refreshed Wheel Bearings
Wheels
- 18” x 8” Rial 5 Split Spokes
- Currently has 18” Snow Tires and will include lightly used 18” Dunlop Summers.
Overall Condition of the Car:
Interior
- Interior is in reasonable condition will some trunk panels currently removed.
- Headliner needs to be re-glued to backer
- Some rattles that can fixed with some patience
- Rattles mostly at idle due to stiff motor mounts
- Extra interior parts to be installed
- This car is not super quiet but not too noisy that it will wake up the neighbourhood.
Exterior
- Small dings on bottom of rockers (before we got the car Pre 2008)
- Paint is still in reasonable condition for its age with no pealing of clearcoat.
Mechanical
- Starts and runs strong
- Does not consume oil
- Handles well and is planted to the road
- No Engine Lights or Warming Lights are on
Most of this work was done 3 years ago and has seen about 7,000 kms of trip/highway driving usually with the small trailer attached.
Comes with a spare 5 speed transaxle the works perfectly but has a small crack in the casting where the dogbone connects that can be fixed by welding.
Comes with an 11mm Injection Pump that I picked up but haven’t installed. (Supposed to work as stated from original owner but I haven’t tested it).
Comes with 2 key fobs and original VW manual.
Price $11,000 CDN (Offers Considered)
