Another example of double and triple checking the vacuum lines for splits and disconnects.
I have been getting the P0299 error for over a year, about every month or so, would go several months sometimes before the error would be logged, and the car would go into Limp mode. Did the tie wrap fix, and tested the actuator, results are in previous comments in this thread.
I remembered reading somewhere on TDIClub, about the vacuum reservoir being
being in the valve cover (always wondered what all those circles were), and about the vacuum line going into the reservoir could be split causing loss of vacuum.
There are certain hills within my weekly/monthly drive were the car with cruise enabled, would generate the P0299 error, and go into Limp mode. I could almost make it occur, if I did not use the throttle to generate more boost before driving up the hill.
Well I checked that vacuum hose going into the reservoir, replaced it for good measure, and also check all my vacuum lines, including the brake booster.
WELL, I found another vacuum line split and disconnected on the backside of the valve cover. Replaced that, and over the past several weeks, during my typical drive over those same hills, the P0299 error did not reoccur.
This fix seems to have also resolved the excess black smoke generated when I would WOT after a lengthy stint of stop and go commuter traffic. Still get a little black smoke, but not as much as before.
