Gabriel
*UPDATE* Decided it's worth the effort, and started the swap..Pics and updates below.
I currently have a base model '01 ALH Jetta GL that I'm considering taking the engine and trans from to swap into an '01 GTI 1.8t auto.
The Jetta has no options whatsoever. It's also a piece of crap. The GTI has power windows, heated seats, moonroof, and an auto trans and is in much better overall condition.
The mechanical aspect seems very straight forward. Swap the engine, trans, axles, shifter etc as one unit. Fuel lines, tank, associated parts. That part I can do in a weekend.
It's the electrical portion that I'm thinking will turn me away from the swap.
I'm getting conflicting info from these mk4 to mk4 swap threads regarding engine and body harness compatibility. Some say if you have the complete engine harness, all you need to do is deal with the immobilizer, key chip, and the fuel relay from the tdi. Other people are splicing and rewiring the complete harness. It wouldn't be so bad if it was Golf to Golf and 5spd to 5spd..At that point it's about getting the engine to run. But I basically am looking at the total opposite..One body style to another, auto to manual trans, no options to all power options and a TDI swap.
So what type of wiring nightmare (or not) am I looking at?
