zslnk
I pulled an OEM junkyard half-shaft to rebuild for a project car that has a loose aftermarket axle on it. The outer was good but the inner needed a boot (joint was OK) and I found that the joint (inner) was somewhat loose on the splines. When I removed the circlip, the joint would slide off the splines. My experience with these is that they are a tight fit and need to be driven on/off with a mallet usually. Are worn splines an issue? The joint and shaft appear to be OEM VW.
