Andyinchville1
Hi All,
I drive a lot at night and was wondering how long the jetta can run If the alternator stops working (charging)
Assume everything is stock and driving at night.
Also, I know on older Cummins 6bt engines the fuel solenoid can be removed and the engine can be turned off using a pull cable .... thus eliminating a forced shutdown when battery power gets too low because the fuel solenoid snaps shut ....
Is there a similar modification that it can be done on the Jetta injection pump?
On the flip side I suppose if power gets so low the computer shuts off the engine will shut off because of that also..
So how long time wise can the car run without a charging alternator?
Thanks in advance for any and all help.
Andrew
Andrew
