DieselDuberrr
Pd150 turbo inlet reducer SOLVED
Hey guys, so I did some searching but I can't find any specifics unfortunately. Trying to figure this out without unbolting the pipe.
Picked up a pd150 tip, maf and airbox for super cheap. Anyway, it didn't come with the reducer that connects the tip to the turbo.
My turbo is a vnt17, and I recall using the alh reducer. But now, I'll be going with whta looks to be a larger tip.
I'm trying to determine if the alh reducer will be fine, or if in gonna have to pick up a pd150 one.
SOLVED: BEW reducer is the same size as the pd130/150 TIP.
