Old December 5th, 2019, 11:00   #1
utoypia
Default 2015 Passat headlight housing replacement
Anyone have replaced their bulbs with LED? For some reason, it's hard to find support for LED high beams. Just low beams.
utoypia is offline   Reply With Quote
Old December 8th, 2019, 05:52   #2
scrambld
I had replaced the low beams w/LED in my '15 Passat. I went back to H7 halogens (PIAA...Lows and Orsam Night Breaker...Highs. The LEDs were too bright and cant be properly aimed (too high of a pattern). I adjusted the headlights down to where I wasn't getting flashed "AS" often, but still was.....I then had no useful high beams.
PS: What does the '15 Passat SEL Prem have for lights? I would assume LED or HID...IDK. At this point the only "best" option for really upgraded lighting would be a take-out OEM set from a Passat equipped with LED/HID....again, not sure what they came with.
scrambld is offline   Reply With Quote
Old December 11th, 2019, 05:59   #3
thundershorts
All 2015 passat se sel headlights are same. Night breaker lasers for both high and lows work quite well, quite white, easy upgrade.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
How to: Remove Headlight Assembly 2015 Passat ? jimbo1mcm VW Passat Family (NMS and B7) TDIs (2012+) 7 November 20th, 2015 01:49
2015 Passat TDI Highline/SEL- Headlight Auto position Lucsar VW Passat Family (NMS and B7) TDIs (2012+) 8 July 19th, 2015 13:44
Headlight housing replacement Briggz TDI 101 3 October 25th, 2014 11:43
NB headlight housing replacement gunnerdd972 Upgrades (non TDI Engine related) 3 August 20th, 2009 13:19
Need to find a replacement Tranmission Housing on a 97 Passat B4 CaptainKirk VW MKIII-A3/B4 TDIs 7 August 30th, 2006 22:30
Page generated in 0.14031 seconds with 11 queries
[Output: 57.24 Kb. compressed to 52.05 Kb. by saving 5.19 Kb. (9.07%)]
