Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi A3
Audi A3 Discussions area for Audi A3 TDI (2010+ in Canada & the US).
Old November 17th, 2019, 17:49   #1
zoomdiesel
Default Engine swap thermostat housing problem
Swapping the motor on a 2011 a3 tdi cbea. Got a donor cbea from an 09 Jetta. My old motor has this thermostat housing https://www.idparts.com/tdi-thermost...87-p-7471.html and the coolant pipe meets the curved elbow on the housing
The replacement motor has this thermostat housing https://www.idparts.com/thermostat-h...ea-p-2321.html and the coolant pipe enters a hole in the block at the housing
I cant use the original housing and coolant pipe because the hole in the block would be exposed. This means I'm missing the top elbow connection which needs to go to the hose that goes to the driver side of the head.
Any easy way to deal with this?
zoomdiesel is offline   Reply With Quote
Old November 18th, 2019, 05:31   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You want a CJAA engine from a 2010-14 G/J/B ideally. If you are using a CBEA engine from a 2009, you'll need to essentially strip the engine down to the long block and put all your 2011 bits on it. Lots of stuff is different on the 2009s.
Seeing how you already have the 2009 engine, you should know that the CBEA has problematic balance shafts in the bottom end, the CJAA does not. For reasons unknown to the rest of us, Audi continued to use the CBEA in the A3 through 2014, but used all the newer bits from the CJAA engine (pressure sensors, thermostat housing, etc.) as well as a few Audi-only bits (fuel filter).
It is also technically not "legal" to install an engine from an OLDER vehicle into a newer car, although nobody will ever in a million years know you did this, and there is technically no difference so long as you install all the 2011 stuff on the 2009 long block anyway.
But seriously, you'd be better off finding a CJAA engine. Which should be MUCH easier, since there were LOTS more of those sold than the CBEA.
oilhammer
www.cardocautomotive.com
Old November 18th, 2019, 09:43   #3
zoomdiesel
I hear you. But, I do already have this cbea engine. What I don't understand is why two engines that are cbea have a different casting...
If I do use this engine is there any solution that is cleaner than adding a tee to an adjacent coolant hose?
Do they make a block off plug for the hole in the block so I can use the cjaa style housing? Is there an easy way to do that otherwise?
Old November 18th, 2019, 10:43   #4
oilhammer
oilhammer's Avatar
Can you get a picture of this extra hole in the block you are talking about? Is it at 90 degrees from the thermostat?
Looking more and more like you should just find a CJAA engine (or, if you prefer, a CBEA from an A3).
oilhammer
Old November 18th, 2019, 15:03   #5
zoomdiesel
Just found that the turbo is blown too. Since my donor is a long block I'll get a cjaa with a good turbo on it instead.
Blown turbo porn: https://photos.app.goo.gl/oWjGcNGdWGxKjvb3A
FYI these are pics of the differences in the two cbea blocks: https://photos.app.goo.gl/GtiGPD99V2Tet6mY8
Old November 20th, 2019, 01:19   #6
Terry270
I I know a guy who makes billet custom thermostat housings for the cjaa that may be able to help you and it is a nice upgrade as well.
Also buying a wrecked car with 80k on it here soon and won't need the turbo if you're interested
2003 2dr Golf TDI-R32 bumpers, sideskirts and wheels, VNT17
2010 Audi A3 TDI-CR170, Malone stg3, ARP headstuds, GLI Brakes, 2micron fuel and serpentine belt protection kits
Terry270 is offline   Reply With Quote
CBEA to CJAA Engine Swap Problem - Thermostat Combine17 TDI 101 5 October 19th, 2016 10:03
Replace Thermostat Housing? bsculthorpe TDI 101 17 July 25th, 2015 20:18
Clip on thermostat housing Big Red VW MKIII-A3/B4 TDIs 3 August 2nd, 2011 20:24
Thermostat housing question ejallison1 VW MKIII-A3/B4 TDIs 5 December 19th, 2010 08:03
Coolant thermostat housing problem POWERSTROKE VW MKIV-A4 TDIs (VE and PD) 8 October 14th, 2004 15:44
Page generated in 0.15615 seconds with 11 queries
[Output: 78.55 Kb. compressed to 68.76 Kb. by saving 9.79 Kb. (12.46%)]
