Old November 27th, 2019, 15:35   #16
greenbubba
greenbubba's Avatar
TDI(s): 2006 Jetta
Fuel Economy: 40
Originally Posted by Matt-98AHU View Post
I've been installing OE China VW radios for people.
Simple, easy to use and figure out, cheap. Easy installation. Bluetooth for calling and audio streaming, though it's maybe a little limited in its function with Android phones as far as controlling streaming via the radio and doesn't import contacts on Android either. But, still streams just fine.
Did I mention cheap? Oh, and if you have a mid 2002 and newer car that already has the factory double din setup (quad lock connector, CAN bus to the radio, Fakra style antenna connector) there is a plug n play adapter that also makes the job easy and even works with the factory steering wheel buttons.
The early 2002 and earlier that were single din from the factory with the ISO wiring, steering wheel controls are not compatible. At least I haven't yet found a LIN to CAN converter for those controls.
RCN210 on AliExpress
If the car you're wanting to install this in is your 2000, you should be the single din with older ISO connector. The adapter this radio automatically comes with is compatible.
If anyone has a 2002 and newer that was double din from the factory with the quadlock connector, there is a different adapter you can buy to make it all plug n play (and again, works with steering wheel controls):
Quadlock adapter and CAN converter
The prices are indeed super cheap, but they'll get you on shipping. So, even with having to order the extra quad lock adapter on later cars, with shipping it could total $120 or more for both items. Still a steal for an OE quality radio that's a nice, near drop-in replacement for Mk4s and B5.5s.
Do you need to worry about ant-theft codes with the Bodenla? My mechanic also said some radios are not compatible with the diagnostic system. I've got a 2006 Jetta.
greenbubba is offline   Reply With Quote
Old December 5th, 2019, 18:17   #17
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
No, you do not.
The radio I linked to, however, is for Mk4 and B5 era cars, not Mk5.
There are a lot of options for the mk5, however, and Bodenla has some of them as well, even has a package to wire in a reverse camera that fits and works like OE.
Found here
A customer of mine bought one for his NMS Passat and likes it a lot. For early mk5s, you may need to buy one of his CAN Bus converters to avoid battery drain issues as well as enable steering wheel button compatibility.
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old December 9th, 2019, 09:23   #18
NewTdi
Fuel Economy: 58/46/39
How difficult is it to retrofit a steering wheel control module/kit in a car that does not currently have that feature?
03 MK IV Sedan 341k miles, BW S7 turbo, RC, PP764, SMIC, 3bar, SB Stage 2 end., PD130/150 TIP - NO SMOKE - Audi TT bushings, Koni Yellow, stock springs.[B]
03 MK IV Wagon 508k miles - GONE TOO SOON
Thank you MATT for the continued car care
NewTdi is offline   Reply With Quote
Old December 9th, 2019, 19:46   #19
hskrdu
Check Lito's notes in this thread, and search MFSW:
https://forums.tdiclub.com/showthread.php?t=37353
Now: 03 Golf GLS TDI 5SPD & (hers) 03 Jetta GLS TDI 5SPD & 2015 GSW TDI 6M
Then: 99 Jetta GLS TDI, 94 Golf GL, 85 Golf GL, 85 Golf, 79 Rabbit C, 68 Beetle, 65 Beetle
hskrdu is online now   Reply With Quote
Old December 10th, 2019, 07:59   #20
NewTdi
I think I can live without the steering wheel controls; I will just upgrade to a 3 spoke steering wheel and be happy with that!
Old December 16th, 2019, 10:47   #21
greenbubba
greenbubba's Avatar
TDI(s): 2006 Jetta
Fuel Economy: 40
Mucho thanks Matt! The battery drain issue is exactly why I want to replace the radio.
Old December 24th, 2019, 16:28   #22
Savageman69
Savageman69's Avatar
love my 8 inch android unit
2012 Touareg v6 TDI - 8spd - Silver - Weathertechs - Buzzken Downpipe/Dpf/Scr Pipes - Hybrid 2260 - 4 Bar Map - JR Auto Performance/Buzzken Stage 3 Tune - 30.5 BFG k02s - 2.5inch Lift - Cayenne Trans Coding - Gutted/Painted Muffler - Full Led Swap - EGR Cooler Delete
2006 Jetta TDI 5pd
Savageman69 is offline   Reply With Quote
Old December 24th, 2019, 19:55   #23
NewTdi
What make/model unit did you install?
Old December 24th, 2019, 20:52   #24
Savageman69
This one its 4gb of ram model
https://www.ebay.ca/itm/9-Android-8-...cAAOSwfCpbI9ty
2006 Jetta TDI 5pd
Old December 26th, 2019, 12:47   #25
hooville
hooville's Avatar
Fuel Economy: 43.2 lifetime average!
Many thanks for this, I have been looking at the Bodenla unit for a while trying to decide if it's the one for the MK4 and you tipped the balance!
FYI, I did the MIB2 upgrade for our MK7 TDI last August and it's not that big a PITA: Start sourcing the hardware you want as deals appear, grab the USB/AUX port from Bodenla and rent the VAS dongle from a MK7 Forum Member when all the pieces are in place. Totally worth the effort, my only regret is not doing it sooner!
Merry Merry to all!
White 2015 Sportwagen S TDI - No Mods...yet!
White 2016 GTI S - A few OEM Mods so far...
Silver 2000 Golf GLS TDI - CAT 2 Filter, Shine Real Street Suspension, Bilsteins, RC3, Nozzles
hooville is offline   Reply With Quote
Old January 8th, 2020, 06:23   #26
pedroYUL
pedroYUL's Avatar
Could you please elaborate, on what and how do you do with the VAS tool to make the MIB2 work?
pedroYUL is offline   Reply With Quote
Radio Pinouts - Premium VI Radio (Double-DIN unit) Michael Moore General VW Discussion 2 March 1st, 2017 08:41
Installing single-DIN radio in place of double-DIN Premium 6 nukefission Upgrades (non TDI Engine related) 3 February 9th, 2009 09:19
conversion from single din to double din radio/cd. silverbeast Upgrades (non TDI Engine related) 7 June 25th, 2005 11:41
conversion from single din to double din radio/cd. silverbeast VW MKIV-A4 TDIs (VE and PD) 0 May 26th, 2005 14:18
Help removing Double Din radio paramedick VW MKIV-A4 TDIs (VE and PD) 12 May 7th, 2005 15:23
Page generated in 0.20069 seconds with 11 queries
[Output: 112.05 Kb. compressed to 95.77 Kb. by saving 16.28 Kb. (14.53%)]
