Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Touareg TDIs
VW Touareg TDIs This is a general discussion about Touareg TDIs. Non TDI related postings will be moved or removed.
Old October 16th, 2019, 22:20   #1
ctennyson
TDI(s): 2010 Jetta
Default Interior Cabin Lights
Weird issue just rose itís head today.
My interior cabin lights stopped working when opening the doors. If I manually turn them on they come on as expected. The light switch is indeed in the correct position to activate when the door is opened.
Is this a common issue ?
Please help
ctennyson is offline   Reply With Quote
Old October 17th, 2019, 08:49   #2
psd1
Fuel Economy: See Fuelly link
Touareg or Jetta?
psd1 is offline   Reply With Quote
Old October 17th, 2019, 09:30   #3
ctennyson
TDI(s): 2010 Jetta
This is a 2012 TouaregTdi
Old October 17th, 2019, 11:21   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You'll need to check the data in the appropriate module to determine if it sees the door(s) open, may even be able to see the reported position of the switch itself as that may also be on there. Cannot say I have ever run into this on a T'reg. Lots and lots of others, though (door latches). But they do not die all at once, and I assume you've tried all four doors.
oilhammer
www.cardocautomotive.com
Old October 20th, 2019, 15:16   #5
ctennyson
TDI(s): 2010 Jetta
Yes tried all four doors, same results every way.
Old October 20th, 2019, 20:45   #6
Gilty_one
Gilty_one's Avatar
So when the Touareg is running - does the dash indicate doors open (when open?)
rear hatch?
Hood?
That will tell you if the door switch is talking to the body control module...
from there you can determine if the light switch is in some mode that won't turn the lights on or off.
I'd get better mileage if I would just drive slower...
Gilty_one is offline   Reply With Quote
Old October 20th, 2019, 20:47   #7
ctennyson
TDI(s): 2010 Jetta
No, when running doors appear to be closed according to the dash
Terminal 30 for Interior Lighting, no interior or tail lights. copilot VW MKVI-A6 Jetta Sedan (~ 2011+) 11 January 31st, 2017 13:49
Interior Cabin filter buckeye96 VW MKV-A5 Golf/Jettas 26 June 27th, 2012 19:59
interior cabin air filter HANKA TDI 101 4 April 12th, 2009 17:44
Interior Cabin Air Filter jettagirl98 TDI 101 2 January 28th, 2008 09:12
Jetta interior lights flash & interior sound? LisaKiv Other VW Group TD(I)s 2 December 31st, 2005 06:34
Page generated in 0.14803 seconds with 11 queries
[Output: 78.51 Kb. compressed to 68.09 Kb. by saving 10.42 Kb. (13.27%)]
