Old May 1st, 2017, 18:05   #1
adjat84th
adjat84th's Avatar
Default MK7 Brake Upgrade
Looking into upgrading brakes on my MK7 Golf and have my eyes set on GTI brakes that come standard with the performance package. In my searching, it appears that only the caliper carriers need to be acquired in order to fit the standard GTI rotors as they use the same caliper as the Golf. In going one step further, it looks as though the carriers from the PP GTI will also work with the difference only being that the PP uses a 60mm piston vs 57mm. My question is, how big of a difference will it make to use the standard 57mm piston calipers on my Golf on a larger 340mm rotor with larger pad where a 60mm piston is used with the PP? This would be far cheaper than going with other big brake kits available out there!
End result update: went with the 18z kit from Rotorlab and am thoroughly happy I went that direction for the increased performance, looks, and cost versus other BBKs. I went into the install thinking I was going to be taking a bunch of pictures, but the process was too simple:
1) raise vehicle and remove wheels
2) remove 2 - 21mm bolts that hold the carrier to the spindle and pry the caliper away from the rotor and set out of the way
3) remove the 1 - T30 screw holding the rotor, then three more T30 screws holding the dust shields to the spindle
4) clean surface of mounting tabs and rotor hub, then mount new rotor with same T30 screw
5) mount new caliper and snug it down to check clearances of the rotor. I ended up using 2.5mm thick washers to bring the caliper inboard which put the rotor within 1mm of center
6) factory torque is 200Nm (147lb-ft) on the factory bolts, so did the same with these
7) threw in Bosch quietcast pads and the 18z kit's included pad hardware
8) install USP Mk4 R32 stainless lines and make sure all connections are snug. Note, ECS tuning uses a different fitting that is keyed to fit a Mk4, not the different Mk7 key. USP just uses a smaller fitting that appears to be rather universal so to speak.
9) I bled all four brakes just because it was due
The pedal will engage lower than stock due to the added volume of the system, but the braking power available is ridiculous. In normal braking situations, and after driving 400 miles on the brakes this weekend, I barely notice it other than when going for a hard stop. There is still the possibility of upgrading to the GTI master cylinder which has a little more capacity, but for now I'm plenty happy with how things are stopping!
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old May 2nd, 2017, 08:34   #2
Ol'Rattler
Ol'Rattler's Avatar
What makes you think you need to upgrade the brakes? Have they gotten that bad since the A5's? My brakes are fantastic, of course I do something many find silly as in not coasting in neutral downhill and up to stops.
Unless your car has really crappy brakes, tires can have a profound effect on braking. I always go with the 40K better traction tires.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old May 2nd, 2017, 16:34   #3
adjat84th
adjat84th's Avatar
A buddy of mine puts it in neutral every time he goes to slow down, drives me crazy. I tell him he's killing his fuel economy and his brakes at the same time!
The brakes are fantastic on the MK7 Golf, just want a bit more to fill the wheel up and also will be doing a few autocross events in the future, so this won't hurt.
Sent from my Pixel using Tapatalk
Old May 3rd, 2017, 15:11   #4
Ol'Rattler
Ol'Rattler's Avatar
Doing a bit of racing could be a good reason for upgrading the brakes. My inclination would be to go with some stickier tires first and then upgrade the brakes when the factory brakes/tires are worn out or are not really working out for your racing use.
Something else to consider as well is what size brakes are on the rear of the GTI and will bigger rotors rub on the inside of your factory wheels?
You can blame Drivers Ed for the decline of the manual transmission. I remember how relieved I was as a young whelp that I didn't have to learn the finer points of driving because all the Drivers Ed cars had automatics.
Just part of the dumbing down of America. Yup. Stupid is the new smart. Your pal is a victim of this............
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old May 3rd, 2017, 15:40   #5
adjat84th
adjat84th's Avatar
Yes, factory wheels on the GTI are 18" and I just switched out my factory 18"s for lighter weight 18"s. Saved five pounds of rotational mass which should be noticeable in the fuel economy. There won't be any fitment issues. My only concern was the use of my stock 57mm pistoned calipers where the GTI w/ PP uses a 60mm piston to push the larger pad onto the larger rotor. I am thinking I'll be ok, but wanted to ask here first before getting just the carriers all around.
Old May 3rd, 2017, 16:29   #6
turbobrick240
turbobrick240's Avatar
I think it should work fine. You'll obviously be getting some of that rotational mass back with the heavier rotors- drilled/slotted ones might not be much heavier.
Old May 4th, 2017, 10:24   #7
adjat84th
adjat84th's Avatar
Turns out the GTI w/ PP rotors are 5mm (25 vs 30) and 10mm thicker (10 vs 20) front and rear respectively. I think that may not work with the TDI's stock calipers unless there's that much travel in the piston to allow that large of a variance especially in the rear?
Old May 5th, 2017, 09:11   #8
20IndigoBlue02
20IndigoBlue02's Avatar
the master cylinder isn't made for the larger piston calipers on the performance pack.
Best bet is the 312mm brake upgrade with better pads.
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old May 5th, 2017, 10:17   #9
adjat84th
adjat84th's Avatar
Correct, the thought was to use only the carriers with the stock calipers because switching the calipers costs quite a bit more, plus you'd have to swap master cylinders as well. But yes, looking like the standard GTI brakes are the only way to go cheaply.
Old May 5th, 2017, 12:48   #10
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
If you must spend money, spend on a proper upgrade not cupra-golf R setup, those are little better than what you have but far away from BBK
Best bang for your $ will be the Z18 caliper upgrade + light 340mm discs
18" wheels of course.
this is my setup, but will upgrade to bigger and lighter discs after the tune
CP3 Upgrade
Macradiators.com is offline   Reply With Quote
Old May 5th, 2017, 20:20   #11
adjat84th
adjat84th's Avatar
^Very nice! Thanks for the suggestion. I'm not in a rush, so this could make the cut.
Old May 8th, 2017, 08:42   #12
20IndigoBlue02
Those calipers, depending on what wheels you have, may not clear the caliper, so you would need spacers.
Just something to take into account
Old May 8th, 2017, 16:54   #13
adjat84th
adjat84th's Avatar
Correct, been doing quite a bit of researching and I believe my new wheels have a bit more room on them with the design of the spokes, but could just run some spacers if needed.
Wondering if the 18Z or 17Z will not affect pedal feel with the stock master cylinder. That would be my biggest concern. Found a great resource for purchasing from a place called Rotorlab that suggests the 18Z may affect pedal feel, so I'm contacting them to see if they have experience with the MK7s.
Old May 9th, 2017, 15:38   #14
Macradiators.com
For sure it will affect pedal travel, little bit longer but braking is so strong
You can upgrade to 25.4mm master cylinder to have a better pedal feel.
I will do this but its not a priority now.
CP3 Upgrade
Old May 9th, 2017, 21:36   #15
3L3M3NT
3L3M3NT's Avatar
Which vehicle are you looking to upgrade?
My best suggestion and like others have mentioned is to put the best tires possible on the car to improve your braking.
https://www.youtube.com/watch?v=uZltSorr9W0
The next thing to do after upgrading to a better set of tires, is going with aftermarket brake pads that are suited to the driving you'll be doing. If you'll be going to some Auto-X events, then go with a set of pads that made for Auto-X.
I've heard good things about http://www.g-locbrakes.com/
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
October 19th,2019 Cruise/GTG in Sturgeon Bay, WI
3L3M3NT is offline   Reply With Quote
For Sale: MK7 Stainless steel foot pedals(gas, brake and clutch) Nutty 5.0 Private TDI Items for Sale/Wanted 2 February 27th, 2017 09:19
MK7 2.0TDI oil pan upgrade options? _Blade_ TDI Power Enhancements 7 October 31st, 2016 04:36
Mk3/B4 Brake Upgrade: Corrado G60 Brake Calipers and Carriers 65k miles G60ING Private TDI Items for Sale/Wanted 4 September 2nd, 2009 05:28
Brake Upgrade 1sparrow Upgrades (non TDI Engine related) 19 January 7th, 2009 07:53
Page generated in 0.16268 seconds with 11 queries
[Output: 138.97 Kb. compressed to 116.65 Kb. by saving 22.32 Kb. (16.06%)]
