Old May 7th, 2019, 16:33   #18841
Sootman
Sootman's Avatar
Fuel Economy: 30 +/- MPG
Default Bought a new to me TDI
I'm back in the diesel world, posted some info in the Mark 6 forum. No mods, no mods, no mods, ah crap of course I do mods.
Sootman
A friend will help you move. A good friend will help you move a body.
2011 VW Golf TDI
http://www.idparts.com/catalog/index.php
Dyno: http://forums.tdiclub.com/showthread.php?t=352348
Sootman is offline   Reply With Quote
Old May 8th, 2019, 03:51   #18842
Welcome back, Sootman!
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old May 8th, 2019, 10:44   #18843
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Originally Posted by kestromb View Post
Yesterday, I wired up the high beams so the low beams stay on simultaneously, also courtesy of the vortex:
https://forums.vwvortex.com/showthread.php?1167457
You didnt do this on stock Jetta headlights, did you?
I would think two filaments burning inside the same glass capsule creating 110 watts of heat would cause the bulb to burn out (or possibly explode).
Of course, if you have aftermarket headlights where the high beam is separate from the low beam, it is not an issue.
Fixmy59bug is offline   Reply With Quote
Old May 8th, 2019, 11:48   #18844
PDiesoiler
PDiesoiler's Avatar
Location: PNW TDI Capital of the World; (ok maybe just the USoA)
TDI(s): TDI-less
Fuel Economy: 37-50mpg/us
Adjusted torsion value from -1.0 to nominal 0 to compensate for belt stretch.
2004 Jetta BEW Pretty much stock 'cept dynamic EGR
PDiesoiler is offline   Reply With Quote
Old June 1st, 2019, 09:59   #18845
nokivasara
nokivasara's Avatar
Fuel Economy: 44-49 mpg
I have worn rotors on my Skoda and lately I've noticed some light vibration under braking so I decided to check the front end before ordering parts, turns out I have a bad front wheel bearing! That's the second time I have a bad bearing (one on both cars) without hearing any rumble beforehand. I'm usually very good at adressing where sounds come from and adjust timing on old IDI's by ear etc, but these bearings take me by surprise for some reason...
Anyway, placed an order on brake discs/pads, wheel bearing, timing belt kit with WP, t-stat and some oil filters.
My Skoda will hit 300k km pretty soon, we'll get a good start on the next 300 with new brakes and tb
nokivasara is offline   Reply With Quote
Old June 3rd, 2019, 13:16   #18846
crashtested
crashtested's Avatar
Thursday past: 90k service - Oil / Air/ Cabin / Fuel filters and new oil.
This weekend was a 900km trip from Nelson to Kalispell, MT for my sons soccer team.
Last night washed off all the bugs and applied new yellow Lamin-x covers to the fogs.
'14 GSW
crashtested is offline   Reply With Quote
Old November 25th, 2019, 11:05   #18847
nokivasara
nokivasara's Avatar
Rebuilt a rear brake caliper on the Golf, it would sometimes drag a bit and get warm.
The piston looked pretty good but the oil seal in the bore was awful, like it was missing small bits and was swollen. Could that happen if the brake fluid isn't changed often enough?
New seals and piston made quite the difference!
Page generated in 0.21915 seconds with 10 queries
[Output: 83.47 Kb. compressed to 72.52 Kb. by saving 10.95 Kb. (13.12%)]
