Rembrant
Hello Folks,
I haven't been on here in a while. My old Jetta has been working that good.
Anyway, this is a strange one, and I just thought I'd reach out and get some feedback on it. A month or two ago, the car started to feel kinda loose in the rear end....not all the time or anything, just seemed like once in a while when hitting a bump while going around a turn, gradual curve, etc. Like a curved offramp with bumps or seams in the road, every time I'd hit one the rear of the car felt like it wiggled a bit...almost like the rear tires were half flat or something.
I went around the car yesterday, and found both rear tires absolutely bald. I mean bald like right through he wear bars and almost no sign of the tread left.
Anyway, they were Michelin Premier A/S tires 245/45-17 or whatever the usual size is, and the front tires were still fine, and looked the same as when I installed them 2-3 months ago. (They were well worn at the time, not new, but were worn evenly).
I stuck my factory 16" rims back on today with Continental Pure Contacts, probably 50% worn, and it seems like the rear end still wiggled a bit going over some bumps.
(I was trying to figure out if the bald tires were causing the weird handling feel, or if there was an issue with the car causing the weird handling and tire wear).
Car has almost exactly 170,000 miles on it. Rear control arms (new aftermarket) were installed by VW dealer a year or so ago when doing an alignment.
Shocks are original, and I haven't had an alignment since...car still drives straight...I didn't think I needed to bother.
Anything in the butt of a Mk5 Jetta that would cause the rear end to get sloppy, or do I just need new shocks and an alignment? It seems like too much of a coincidence that the car has ruined two rear tires so quickly.
Any thoughts? Am I insane...lol?
