Got the car back this afternoon! First impressions: The car is the same as it was before the modification. Sounds the same, pulls the same. On my normal 37 mile drive home from work (98% Freeway/Interstate) I got 46 mpg which is what I usually get on that drive at that time of day. Overall, I'm happy.
I did scan the car with VAGcom before I did the modification and scanned it again today when I got home. There are no check engine lights on btw. One thing I noted though was that there were stored "malfunctions" in the Autoscan post-modification. I think most of these are due to the battery probably being drained while the dealer did the ECU reflash. My voltage gage was reading pretty low while the car was running. I'm sure they just left the ignition on while the car was flashed. Here are my two scans. The first is pre-modification and the second is post-modification. Let me know your thoughts.
Finally, I did receive a new exhaust flap, EGR filter, NOx cat, and the two proof of modification stickers stuck to the underside of my hood (no sound blanket).
I think this thread should be a sticky eventually as more people receive the modification. Happy driving!
SCAN BEFORE EMISSIONS MODIFICATION
Tuesday,15,August,2017,20:07:28:09721
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWBM7AJ8AW381317 License Plate:
Mileage: 151453mi Repair Order: Scan before emission fix
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 47 52 55 56 65
77
VIN: WVWBM7AJ8AW381317 Mileage: 243740km-151453miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CM HW: 03L 906 022 TS
Component: R4 2,0L EDC G000AG 7967
Revision: 12H03--- Serial number:
Coding: 0050078
Shop #: WSC 26118 444 84949
VCID: 78D132840BF6B286B2-802C
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 052 T HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2114
Revision: 51112 Serial number: 00001003151620
Coding: 0000020
Shop #: WSC 01357 011 00200
VCID: 256F2BF0ECC4FF6ED9-8070
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B400C492A00FB880E02E592200042310000
VCID: 7AD5288CF5FAA096C4-802E
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 3C8 907 336 AH HW: 3C8 907 336 AH
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW36.rod
VCID: 73CB05A8DA90D1DE87-8026
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0576
Revision: 00103 AF
Coding: 6D180A3F90272A04808800812000898447050086534D8160648020200000
Shop #: WSC 25016 444 13901
VCID: 354FFBB09C648FEE69-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 29031 21 0512
Coding: 009795
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0AUXYA
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3957F780B87C6B8E8D-806C
Seat occupied recognition:
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0005444A00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME58502252ZZZM
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME35486351ZZZT
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME202C5715ZZZP
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME0A0D5263ZZZV
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME2C083321ZZZ7
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME7C093321ZZZE
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001632
VCID: 76CD3CBC01E2C4F6A0-8022
Subsystem 1 - Part No: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Coding: 00000227
Shop #: WSC 00000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5K0 920 970 Q HW: 5K0 920 970 Q
Component: KOMBI H03 0305
Serial number: 00000000000000
Coding: 270F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
VCID: 3C59EE94B74E5EA696-8068
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 300310F2001776
Coding: ED811F07500612000000
VCID: 69F767C0405C1B0E3D-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6AF518CC8D5A101634-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667923478
Coding: 010000
VCID: 266D2CFC51C2F476D0-8072
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 C HW: 3C0 035 684 C
Component: RNS-MID H06 1000
Revision: AB001001 Serial number: VWZ6Z7K7086019
Coding: 040700000100008600
VCID: 236B35E822F0015EB7-8076
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 196
Reset counter: 45
Mileage: 239768 km
Time Indication: 0
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2111
Coding: 0001076
VCID: 3147CFA0A80CA3CE35-8064
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Address 47: Sound System (R12) Labels: None
Part No HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218109081776
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: 558F5B303424AFEE89-8000
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Component: Tuer-SG 009 2137
Coding: 0001076
VCID: 3449C6B4571E96E65E-8060
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 1446940
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0005
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0005
Coding: 00000022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 45
Mileage: 239768 km
Time Indication: 0
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 103 0521
Coding: 018705
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000330873003
Coding: 412100
VCID: 2A75D8CC45DAD016F4-807E
End-------------------------(Elapsed Time: 01:53)--------------------------
___________________________________________________________________________
_____________________________________________________________________________
SCAN AFTER EMISSIONS MODIFICATION
Monday,21,August,2017,16:33:55:09721
www.Ross-Tech.com
VIN: WVWBM7AJ8AW381317 License Plate: POST_FIX_CODES
Mileage: 243890km-151546mi Repair Order:
77
VIN: WVWBM7AJ8AW381317 Mileage: 243890km-151546miles
01-Engine -- Status: Sporadic communication error 1000
02-Auto Trans -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 1010
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Sporadic communication error 1000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CJA) Labels: None
Part No SW: 03L 997 030 K HW: 03L 906 022 TS
Component: R4 2.0l TDI G001AG 9983
Coding: 0050078
Shop #: WSC 03998 002 1048576
VCID: 364DFCBC416284F660-8062
Component: GSG DSG AG6 511 9037
Coding: 0000020
Revision: 00H30001
3 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 88
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 09:32:30
Freeze Frame:
Count: 7
Count: 15
Count: 20480
Count: 128
Count: 28672
Count: 1
Count: 0
Count: 0
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 11:52:15
Freeze Frame:
Count: 0
Count: 14
Count: 20480
Count: 8194
Count: 45312
Count: 1
Count: 255
Count: 0
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 12:00:34
Freeze Frame:
Count: 2
Count: 14
Count: 20480
Count: 8195
Count: 45568
Count: 1
Count: 255
Count: 0
Revision: 00009001
Coding: 0000001002
Component: BCM PQ35 H+ 103 0578
Revision: 00103 AF
Coding: 009795
5 Faults Found:
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 87
Mileage: 243815 km
Time Indication: 0
Date: 2012.01.08
Time: 13:56:22
Freeze Frame:
Term 15 Off
Voltage: 8.90 V
OFF
ON
Term 50 Off
OFF
OFF
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 09:36:31
Freeze Frame:
Term 15 On
Voltage: 7.95 V
ON
ON
Term 50 Off
OFF
OFF
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 09:39:16
Freeze Frame:
Term 15 On
Voltage: 7.95 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 11:52:15
Freeze Frame:
Term 15 On
Voltage: 12.75 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 12:00:35
Freeze Frame:
Term 15 On
Voltage: 12.80 V
ON
ON
Term 50 Off
OFF
OFF
Coding: 00003031
Coding: 0001632
Coding: 00000227
Shop #: WSC 00000
4 Faults Found:
00002 - Transmission Control Unit
00457 - Control Module for Network (J519)
Coding: 270F00
8 Faults Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 11:52:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 12:00:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 12:03:19
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 12:03:19
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 12:03:18
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 31
Reset counter: 48
Mileage: 243815 km
Time Indication: 0
Date: 2012.01.08
Time: 13:58:20
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Reset counter: 48
Mileage: 243815 km
Time Indication: 0
Date: 2012.01.08
Time: 13:58:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 09:01:57
Coding: 000000
Coding: 010000
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 87
Mileage: 243815 km
Time Indication: 0
Date: 2012.01.08
Time: 13:55:19
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 48
Mileage: 243815 km
Time Indication: 0
Date: 2012.01.08
Time: 13:58:21
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 09:06:04
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 12:03:22
Cannot be reached
Coding: 0001076
3 Faults Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Revision: 00H17000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 11:52:15
Freeze Frame:
Voltage: 12.63 V
DU
Temperature: 35.0°C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 HW: 5K0 035 456
VCID: 67F361F89E482D7E2B-8032
Coding: 0001076
2 Faults Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Coding: 1446940
Coding: 00000022
Coding: 00000022
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 11:52:15
Freeze Frame:
Voltage: 12.64 V
Speed: 0.0 km/h
ABS 1
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 12:03:16
Freeze Frame:
Voltage: 12.92 V
Speed: 0.0 km/h
ABS 1
Address 56: Radio
Cannot be reached
Coding: 018705
Coding: 412100
4 Faults Found:
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 09:02:55
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 09:03:55
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 243816 km
Time Indication: 0
Date: 2012.01.12
Time: 12:03:26
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 47
Mileage: 243815 km
Time Indication: 0
Date: 2012.01.08
Time: 13:59:19
