STRANGETDI
- Joined
- Sep 20, 2001
- Location
- East Hampton, CT
- TDI
- 2013 Audi A3 S-Line Premium Plus Quattro - APR Stage II
"If you are starting with an A4 5-speed manual with Upsolute or Wetterauer chip, don't even think about 0.216 injectors unless you're prepared for internal engine work to lower compression, a slightly larger turbo (but not too much!) such as a VNT17, custom intercooler, upgraded clutch, upgraded final drive, better oil cooling, custom ECU programming to deal with all the issues that will occur. This will cost thousands of dollars to get right. Long term durability under high load conditions is not likely to be very good."
Do I really have to do these? Or are these suggestions done to maximize the performance of the .216s? If I just did the VAG-COM EGr mod (or the DG race pipe), change the idle injection quantity, the-1 vnt adjustment, clutch upgrade. would that be enough? What could I get away with installing .216s? Is anyone running .216s w/ a chip?
I am planning on getting .205s but was just wondering if I really need to do all the upgrades/modifications if i did (hypothetically) get .216s.
Also, I don't drive like an as*hole either, just want the power if I ever decide to drive like one (when ricey cars want to step up to the plate an show off)
Just a question from a fellow TDIer who wants a higher powered TDI.
BTW, GoFaster, I am not questioning your FAQ revisions, just curious as to why you can't do the same mods to the .216s, as you would the .205s. I value your opinion a lot just like I value many others' on these forums.
[ December 06, 2002, 14:38: Message edited by: STRANGETDI ]
