Old January 26th, 2012, 23:56   #16
Kite_rider
TDI(s): 2010 JSW
I'm looking for a lift too. Probably not 2" though. I had put in the Firestone Ride Rite bags, they didn't lift it at all, but they did help the sagging rear end - till one stoped functioning.
I just lifted my Eurovan and it was easier than I expected. Put a nylon pad between my rear coil spring and the upper frame. The front was easy since it had torsion bars. Not the same for the Sportwagen. Anyway, please do update us on your progress.
2010 JSW - White Gold - 6sp manual
Kite_rider is offline   Reply With Quote
Old February 10th, 2012, 05:24   #17
dslman
dslman's Avatar
Fuel Economy: 59.96/42/37 US miles per US gallon
Default Any Luck on a Lift kit?
I'm wanting a LIFT too, (2012 Golf) The car is too low. I would GLADLY have paid for a tiguan instead of a Golf, but ALAS, NO DIESEL!
I almost bought a Touareg, but after test driving one, it felt & looked EXACTLY like the Golf, (only bigger & heavier) It rode better too, but for $60 grand I can buy 2 Golfs, just not worth it.
I don't know what is the deal with all these lowered cars, I think lowered looks like crap, and worse I see people lowering their Tiguans? What's with that? It's suppose to be a truck, not a slot car.
Anyways, any luck on a solution?
I wish my suspension was softer riding too, my 2000 Golf rides 1000 times better than the 2012.
Too low and too stiff.
I want my 2012 TDI to ride like my 2000 TDI & at least 1" higher.
dslman is offline   Reply With Quote
Old February 10th, 2012, 09:21   #18
GraniteRooster
GraniteRooster's Avatar
TDI(s): '12 JSW 6MT
Fuel Economy: 41 Winter | 45 Summer
It seems to me that a logical way to do a JSW or Golf lift would be to use OEM springs from a foreign market with higher cars. For example, I believe in Canada and Brazil Golfs have a higher ride height and smaller wheels to deal with worse roads. (Examples: Golf Brazil, Jetta Variant Brazil)
I wonder if JSW's or Jetta's are available with higher ride height as well? It seems like somewhere there ought to be OEM VW springs with correct height and spring rate for the JSW. Perhaps a member here who is a suspension and VW parts number wizard can supply P/N's
Combine with slightly larger tires & OEM suspension limiters to make JSW Alltrack!!
2012 JSW | 6MT | Candy White | Cornsilk | Pano Roof | Huper Optik ESC 45 | Sport Protection Kit | Panzer Plate | VCDS
^^~^^ Mambo | X-Ice Xi2 ^^~^^ Goal | Pilot Super Sport
FOR SALE: '12 Jetta Sportwagen 6MT
GraniteRooster is offline   Reply With Quote
Old February 10th, 2012, 11:57   #19
ToeBall
Don't need a lift. Mine's lowered and on oversize tires.
CRW_5652 by Toe_Ball, on Flickr
2010 VW JSW TDI "Barley", 6-speed manual, Blue Graphite - 255/40's on 18x8's, Sigma6, B&M Shifter, Malone Stage 2, Koni coilovers w/H&R springs, 28mm front/27mm rear swaybars, GTD Grill, 900W stereo, PDE downpipe, Banks exhaust, APR intake, Votex kit.
ToeBall is offline   Reply With Quote
Old February 10th, 2012, 17:50   #20
dslman
dslman's Avatar
Default Tiguan Springs
I know there are Tiguan owners who swapped in Jetta HR Springs to lower their Tiguans.
I was thinking OK, that will work the other way too, I could put Tiguan springs on my Golf, however after looking closer, I think it would lift it TOO much, if it even worked at all.
The weight is not really a big deal as a 4 Door GOLF TDI only weighs about 379 lbs less than a 2WD Tiguan with a Petrol Motor.
I like what this guy did:
... But I don't want to go to this extent, although I REALLY Love this! Especially on the rough roads I drive, this would be awesome. Any lowered car would be demolished trying to drive on these roads.
Maybe I should just build a buggy & put a TDI engine in it.
Old February 10th, 2012, 17:53   #21
dslman
dslman's Avatar
This is a Beautiful wagon, but I would not want to drive this on the rough roads I use, it would demolish it.
Old February 11th, 2012, 07:42   #22
GraniteRooster
TDI(s): '12 JSW 6MT
For the previous generation Jetta Wagon VW made Towing Package Springs that raised ride height about 3/4". There is a thread on fitment here, and IDParts sells them here. I wonder if a similar item is available for the new JSW aka Golf Estate, Variant, etc?
Old February 17th, 2012, 11:17   #23
dslman
dslman's Avatar
Default Lifted Mk6
Can anyone here tell me the best or easiest way I can determine what my 2012 Golf TDI stock OEM Spring Part numbers are?
I'm going to have Coil Spring Specialties make me custom coil springs with 1.5" to 2" of lift and 20% softer ride quality.
Iíll find a way to disable or trick ESC if it interferes, there has to be a way.
I sold the stock 225/45/17 wheels & tires, replaced with 195/65/15 Michelin Primacy MXV4 but to my surprise, it didnít help ride quality much. Steering became
a whole lot easier, & MPG went up, and... although ride quality may be slightly better, it's still way way too stiff, and I donít like the stock lowered looking sport suspension & I just can't stand it. Way too low too, it scrapes on even slightly uneven roads or driveways.
I always wanted to lift My stock 2000 Golf TDI which completely stock is already higher than the 2012, & it Rides like a Buick in comparison, which I always loved.
Old July 17th, 2012, 18:53   #24
wfg97079
Default miss mine
Miss my 03 Golf with the 2" lift. Would love to lift my JSW.
Originally Posted by frugality View Post
This was my 2000 Golf with a 2" lift and stock tires:
wfg97079 is offline   Reply With Quote
Old July 17th, 2012, 18:55   #25
wfg97079
Default nice
I think the 2" lift made for a great snowrunner up here in the northeast too.
Old July 19th, 2012, 04:50   #26
ToeBall
You may want to consider doing a good set of coilovers. I'm not talking about drop coilovers but a proper rally car suspension.
Old July 20th, 2012, 08:03   #27
Jon_Mutiger
Any word on how this is progressing? I like the idea of a taller car as well for the backroads I drive it would be quite handy.
Jon
Motorcycle maniac.. MX, Enduro, Hare Scrambles.. My TDI gets me there cheap!
Jon_Mutiger is offline   Reply With Quote
Old September 15th, 2012, 17:34   #28
Jon_Mutiger
I was just wondering what is actually needed to convert a golf to a tiguan height wise..
I would imagine:
Front:
New lower control arms, longer struts, longer Front axles, perhaps a different brake/hub assembly
Rear:
Longer lower control arm, longer link arms, different upright/hub/brake
Anyone got a real list of stuff required to do this? I would actually seriously consider doing this to my golf, but I would make it look more car and less SUV.
Jon
Old September 16th, 2012, 15:32   #29
emus528
TDI(s): See sig
I'm looking to raise my 2013 4dr Golf as well. There are quite few different TIG springs listed in ETKA. It would be nice if that is all it requires but we would still need to sort the different springs' rates I suppose.
1987 Vanagon Syncro // Westfalia pop-top graft // ALH (Rebuilt with head from Franko6. ASV 0.5mm Oversize pistons). AFN 110 RC 2,3,4 // VNT 17 // PP520's
2013 Golf 4d TDI. No mods. Yet.
1991 Jetta coupe TD. Giles Superpump. Custom tall 5
speed from AA Transaxle.
emus528 is offline   Reply With Quote
Old September 20th, 2012, 23:23   #30
Jon_Mutiger
Now that I've been towing with my golf a bit, the Curt hitch simply is too low. I need to get the rear of the car, and soon. Can someone chime in on what springs will fit this car, and raise it up? I think the tiguan springs will work, but the angles of the suspension will probably get messed up. I plan on putting Bilstein HD's in, and some heavier springs. The shorter dampers will limit travel, and the heavier springs will probably top out the dampers almost all of the time. It might be a bad combo for handling.
Lift for TDI Sportwagen (for oversize tires) BioDieselLover VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 January 25th, 2012 08:37
Resetting for oversize tires. Lightflyer1 OBD Scanners 6 March 24th, 2011 23:36
Do oversize tires cause problems with ABS or ESP? wesmontage VW MKIV-A4 TDIs (VE and PD) 7 August 27th, 2010 21:21
Tires for '09 Sportwagen TDI tdiatlast VW MKV-A5 Golf/Jettas 7 January 27th, 2009 05:55
Any Advantages of Oversize Tires? jaberoo Upgrades (non TDI Engine related) 8 February 19th, 2007 19:39
Page generated in 0.19075 seconds with 13 queries
[Output: 138.94 Kb. compressed to 117.21 Kb. by saving 21.73 Kb. (15.64%)]
