The temp sensor is actually mounted to the turbo on the back side near firewall, part number 058906088A 17mm wrench (tight fit) the connector is located on the top of the engine almost center but off to passenger side a little, it's right next to an orange connector that is the exact size (they can be swapped if a small tang is cut off) mine was reading max temp (over 800 c) with engine cold
