CTD_Chevrolet
I just got this code in my 2015 at ~7,995 miles. Here's the full error:
The DPF light was on when I parked and left town for 5 days, just got home to go for a drive to regen and the CEL was on when I started it. Should I figure it was due to the other conditions and clear it, or leave it and make an appointment at the dealership? It doesn't bother me much if I clear it and it comes back, but I don't want it to suddenly poop the bed on a road trip and screw me.
Code:
9162 - Sensor for Exhaust Flap
P048C 00 [232] - Implausible Signal
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 12840 km
Date: 2030.14.06
Time: 01:12:03
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: -9 °C
Intake air temperature: -8 °C
Ambient air pressure: 850 mbar
Voltage terminal 30: 11.720 V
Dynamic environmental data: 20 96
Unlearning counter according OBD: 40
Particle filter outlet temp.sens.1 bank 1: raw value: -9.6 °C
Exh.recircul.valve 1 bank 1: pos.feedback - Spec.value: 0.00 %
Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 90.64 %
Exh.recircul.valve 1 bank 1: pos.feedback -Offset closed.: 0.00 %
Exhaust recirculation valve 1 bank 1: monitoring - status-Bit 0: 0
Exhaust recirculation valve 1 bank 1: monitoring - status-Bit 16: 8
Exhaust recirculation valve 1 bank 1: monitoring - status-Bit 24: 55
Exhaust recirculation valve 1 bank 1: monitoring - status-Bit 8: 66
Exh.recircul.valve 1 bank 1: pos.feedback - Uncnd vlt: 1006.6 mV
