borjawil
06 BRM 1.9 200K
Is it possible the "STOP oil pressure" comes on from too much oil? Does not say low oil or low pressure. Oil level is at the top ball on my dip stick.
If not then Im thinking a sensor, wiring, or pump issue? I know the harnesses tend to rub and short. I had to deal with this shortly after purchasing the car and put a used good one in which solved the issues i was having. None of the other common issues are occurring from a harness rub.
How do I test the pressure sensor, wiring, and pump to make sure? Read theres an oil pump chain you can see if you drop the pan?
