Old August 28th, 2011, 05:11   #1261
WVU TDI
WVU TDI's Avatar
Originally Posted by rotarykid View Post
2) they are usually full time in a car with no option to disable them which can cost as much as 10 mpgs or more.
brb, gonna go get 33mpg in my 2010 Legacy.
1997 Passat TDI (sold)
2001 Golf TDI (sold)
2010 4dr Golf TDI, 6M (sold)
2013 Passat TDI SE, 6M -- turbo failed at 9500 miles.
WVU TDI is offline   Reply With Quote
Old August 28th, 2011, 05:16   #1262
donDavide
donDavide's Avatar
Fuel Economy: 51/45/40
The best I have gotten in my GC CRD is a little over 24mpg, I have seen others say the have gotten close to 30.
2003 Jetta GLS TDi TTbushings
2005 Passat GLS TDI Wagon Stone Henge Gray
2007 Jeep Grand Cherokee CRD
donDavide is offline   Reply With Quote
Old August 28th, 2011, 08:46   #1263
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
But your GC CRD isn't a car with a 4-cylinder diesel, it's a truck with a V6.
Make your GC the size of a Passat, and lop two cylinders off, then we can talk.
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is offline   Reply With Quote
Old August 28th, 2011, 09:18   #1264
Derrel H Green
Derrel H Green's Avatar
Fuel Economy: Check my Fuelly
Default Older Jeep Four Cylinder Diesel
Try this one on for size:
http://www.fueleconomy.gov/feg/calcu...umn=1&id=22529
Compare how much better this 2.8L four banger (Italian) with 4WD diesel does
when figuring the lower miles per gallon of even the manual tranny 3.7 gasser!
I drove a used one a few years ago with 9K miles on the odometer that was on
a lot here in Southern California (San Diego) and it was fully loaded with
the original sticker in the glove compartment. Very nice indeed.
D
2010 JSW. Reflex Silver/Titan Interior. A TDI with DSG.
Dynoed 132 HP, 230 ft/lb torque at the wheels.
Traded the VW for a Mercedes Benz W-211 E-320 CDI 12-17-2011.
Dynoed 12-01-12 211 HP, 386 ft/lb torque at the wheels.
View my MBZ E-320 CDI Fuelly: http://www.fuelly.com/driver/derrelhgreen/E320
Compare our previous VW TDI JSW DSG Fuelly : http://www.fuelly.com/driver/derrelhgreen/Jetta
Derrel H Green is offline   Reply With Quote
Old August 28th, 2011, 10:09   #1265
donDavide
donDavide's Avatar
You missed my point.
Old August 28th, 2011, 11:54   #1266
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
True, the GC gets (and sometimes beats) the figures that rotarykid claimed a 4-cylinder car would get, while being a 6-cylinder truck.
Old August 29th, 2011, 05:45   #1267
oxford_guy
TDI(s): Golf '11
Can the RNS 510 be added later to an SE Passat? What about KESSY and remote start?
If so, how difficult would it be? A friend of mine likes the NAV in the SEL but doesn't want to pay for all the other SEL features and doesn't want the lower-resolution NAV offered in the SE.
oxford_guy is offline   Reply With Quote
Old August 29th, 2011, 06:04   #1268
German_1er_diesel
German_1er_diesel's Avatar
TDI(s): BMW 118d
The RNS510 is very expensive if bought standalone. I'd rather install Kenwood's excellent DNX520VBT at half the cost.
http://www.kenwood-electronics.co.uk.../vw/DNX520VBT/
BMW 118d hatchback
German_1er_diesel is offline   Reply With Quote
Old August 29th, 2011, 07:43   #1269
oxford_guy
TDI(s): Golf '11
Looks like that thing is very expensive, too. Maybe he should get one of the Chinese units... Otherwise, it seems like it's a better deal to just buy the SEL. Do you know of a place that sells the Kenwood at a good price?
FSF: Fuel System Failure. "Since the CR fuel system failure is so expensive, ... " eddif
Old August 29th, 2011, 09:02   #1270
verylongdrive
TDI(s): Golf,2001
Fuel Economy: 43/46/50
Question
The Passat Trims & Specs section of the VW website which was first plain useless and later blank, now has separate information for each trim level. (Sadly, the "text" version has no vertical alignment of features between specs so it's hard to compare.)
It lists:
No "chrome protective strips" except on the upper trim levels - are those sill protectors, at the bottom of the door edge, or the desperately necessary midlle-of-door ding pcatchers?
"Rear passenger ventilation for heat and A/C". As the pictures of the rear of the console (none on the VW website itself) show no vents, I guess this means under-seat vents, if true at all?
SE: "Power lumbar for driver seat, manual for passenger"
Manual lumbar support would get me most the way to comfort (and hopefully make power lumbar easier to retrofit, if it's no a whole different system).
But that is new, and not mentioned anywhere else except the standard/optional features table (with the same wording).
But then, the text also lists no foglights on TDI-SE/nav and TDI-SEL even though the pictures above show them, so my trust in this is limited.
Worse, the table says only these two top trim levels get 12V outlets, while the text also list them for the SE-manual but not the SE-DSG.
While it's nuts to exclude these on any trim level (spending plastic molding NRE money to make the cover to take away a feature...), it's believeable, but again, there is a contradiction.
I'd really like to know what's what, but now I can't find the 800-VW-gives-a- number.
I wonder about German engineering vs. American marketing in all this,
but then I see things like "side marker", which is noteworthy because a) though a US brochure writer may still be silly enough to list these like not every car in the US has them, a German would be more likely to do so since they've only been legal, much less common, there for a few years, and b) only a German would (based on the way it is in German) think that the plural of "marker" is "marker".
verylongdrive is offline   Reply With Quote
Old August 29th, 2011, 12:55   #1271
oxford_guy
TDI(s): Golf '11
Originally Posted by verylongdrive View Post
It lists:
http://terryatamian.com/wp-content/u...012-passat.jpg
http://web.vw.com/blogassets/passat/...otor-Trend.jpg
http://www.autocenterblog.com/wp-con...n-Passat-3.jpg
http://4.bp.blogspot.com/_FoXyvaPSnV...sat-USA-15.JPG
http://www.cheersandgears.com/upload..._76_363477.jpg
The TDI SE doesn't have the chrome and looks like the 2.5 gas model unless you get the Nav trim:
SE gas:
http://images.autoconx.com/Photos/086/503599086_1_B.jpg
http://cdn8.wn.com/ph/img/d6/15/be7b...4b0-grande.jpg
It must, because the SEL cars at dealerships don't have rear middle vents.
Old August 29th, 2011, 19:10   #1272
jcasari
I just saw the SEL TDI at a dealership:
It does have under seat vents. Also, the center vents from the front blow very hard. I'm in Houston and it is currently 106 outside and I was impressed how well the car was cooling in the back seat. Not sure how much the under seat vents contributed, but the front center vents were blowing so well that I could feel a breeze in the back seat. I had test driven a Lexus ES350 earlier the same day, with rear vents, and it was not as good for me as the vents blew on my leg but not my body.
Also, the salesman told me that they were adding the vents in the rear center console but it would not be there for the first delivery (which he expected in early October). The second batch (late October delivery) was expected to have the rear vents. Not sure if this is accurate or not but according to the salesman it was a major oversight that they realized they needed to correct and could not wait until the next year model.
Jorge
jcasari is offline   Reply With Quote
Old August 29th, 2011, 19:32   #1273
oxford_guy
TDI(s): Golf '11
That's ridiculously unfair for those who ordered the first batch.
Old August 29th, 2011, 19:53   #1274
donDavide
donDavide's Avatar
Back a few pages i saw sombudy say Tdeyez were black and gassers sliver, i saw a black gasser @ waterfest, along wit tdi
Old August 30th, 2011, 06:13   #1275
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
Those that ordered the first batch ordered them with the knowledge that they didn't have center vents. And, it's common knowledge that VW changes stuff quite often in the first model year of a car.
If they want center vents, I hear there's this program called ETKA that gives you part numbers.
New Polo confirmed for the USA, with TDI characterzero TDI News/Tech 516 May 21st, 2012 18:40
Rabbit GT TDI confirmed at Dealer Meeting twigless General VW Discussion 45 February 25th, 2011 05:16
2010 TDI golf confirmed for North America winterlocked VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 956 May 29th, 2010 19:16
Possible fuel pump "confirmed kill" with a 96 tdi ybiofuels Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 5 August 17th, 2004 09:04
Confirmed: Not all MkIV's have immobilizers! TDIBri VW MKIV-A4 TDIs (VE and PD) 22 April 8th, 2004 12:10
Page generated in 0.11550 seconds with 11 queries
[Output: 140.18 Kb. compressed to 118.17 Kb. by saving 22.01 Kb. (15.70%)]
