Rear brake problems:
1) VW put a helical mechanical adjuster inside the caliper with a shaft sticking out.
2) It's a floating caliper, not floating piston design.
3) The calipers are uncoated aluminum.
4) The new boots in replacement pad kits are as water tight as a screen.
5) The "pad retaining springs" (the steel plates between the brake pads and the caliper bracket) in most replacement pad kits are black oxide coated (OEM is stainless).
6) The brake hydraulic system is open to the atmosphere.
Items 1, 2 & 3 are manufacturing cost savers, if the car makes it out of warrantee, who cares?
Items 1 and 3 expose the parking brake mechanics to a high potential for corrosion which will bind the parking brake shaft, especially here in the rust belt. This is a large contributor to not having the parking brake release, the shaft corrodes in the brass bushing in the caliper due to exposure to the crap they put on the roads in the winter.
Item 4 is a problem for stuck (not floating) calipers, the parking brake may be functioning but if the caliper is stuck on the pin, it will drag the brake. I reuse the VW parts because they seal on both ends and keep the water out.
Items 3 & 5 are a problem that will cause a pad to drag because it can't move in the caliper like it is designed to when the brake pedal is released. I picked up a set of warrantee replacement pads from AutoZone the other day and they appear to have SS parts again. The oxide coated parts jammed tight very quickly due to corrosion.
Item 6, the unsealed hydraulic system. The recommended maintenance states that the brake fluid should be changed every 2 years, most newer ABS system equipped vehicles do this to keep the fluid serviceable in these high cycle frequency systems. But, THERE IS NO SEAL ON THE BRAKE FLUID RESERVOIR TO KEEP THE FLUID FROM ABSORBING MOISTURE FROM THE ATMOSPHERE! Nothing! There's actually a freaking vent hole in the filler cap (but you might have to break it to find it). I discovered this awesome feature while making my pressure bleed system (the best way to bleed these cars).
To keep these systems working you need to:
- Change the fluid every 2 years.
- Use SS parts on the rear calipers.
- Make sure the pads are free to move in the caliper bracket.
- Make sure the calipers can move on the pins.
- Use pin boots that seal tight on both ends.
- Use a good weatherproof lube on the pins and the pad edges. (I'm trying Sta-Lube synthetic brake and caliper lube. I've tried Copper anti-seize and Syl-glyde but neither lasts).
- Check and re-lube everything periodically. I re-lube the pins and make sure the pads can float every spring when I put the summer tires on.
These are high maintenance systems but if you stay on top of it, they do work pretty good.
