MareIslandTDI
I know on the MK5, a lot of people swap out the plastic DV for a Forge Motorsport one, anyone replaced one on a MK6 Golf TDI?
Okay, so is there a way to make it louder?You should learn about how a dual-throttled, dual-EGR turbo diesel works before you go talking about noise and diverter valves.
Okay i get that. But i want to see if they have one that sits in front on the bottom end of the bumper so its seen..??And ... Your car already has an enormous front-mounted intercooler that's the same frontal area as the entire main radiator.
Forge twincooler.Okay i get that. But i want to see if they have one that sits in front on the bottom end of the bumper so its seen..??
You bought the wrong car kid. Go trade it in for a 2.0T or 1.8TOkay so i understand that this does absolutely nothing for the car but i want the noise. I hear the noise witht my current intake but its not loud enough for me. Has anyone found a diverter valve that would fit the mk6 tdi?
Also has anyone found a front mount inter cooler for the mk6 tdi??
Nope.Then a bov would be needed to regulate the boost pressure.
Wastegates haven't been used on North American TDIs since 1999, and have been replaced by variable vanes inside the turbine housing that modify airflow over the turbine wheel.Nope.
Wastegate does that.
(here's five characters so the forum software's happy)Now, if one were to swap the turbo for a standard style turbo,
