Sharkey
Hi All,
I'm the proud owner of a 2005 TDI Golf that I bought a little over a month ago and in trying to track down the reason my oil light keeps coming on/going off, I finally got my hands on the service records from the dealer and got a bit of a surprise. It turns out that the engine was replaced a little over a year ago (I spoke with someone at the shop today and he was good enough to answer a couple of questions for me) because of a problem with the high-pressure fuel pump. Before the replacement was put in, it had a timing belt/water pump replaced, new glow plugs, the (nearly new) high-pressure fuel pump (that had been ordered too late to save the old engine) and within the last year, a new oil pump put in. It also had the auto transmission rebuilt last March due to a reverse gear problem.
I LOVE the car and it's actually the 13th VW I've owned (the 3rd diesel but BY FAR the most sophisticated - the last one was an '87 Jetta) on all of which I've done most of the maintenance myself. Now that I'm chasing down the oil light problem (I've replaced the high-pressure sensor on the oil filter base) I'm unsure what path to follow in that I don't know if the engine that they replaced the original with is a PD. Since the oil pump was replaced in March of this year, my next course of action is going to be to make sure the pressure is OK with a gauge and if everything looks OK (by the way, I couldn't find a pressure chart for PSI/BAR per RPM so if anyone has a source I'd appreciate it!) but I want to make sure I've got the engine model/type figured out before I do much else.
Any thoughts would be hugely appreciated!
Mahalo,
Sharkey
Mahalo,
Sharkey
