shawna74
Looking for direction on an issue i am having on my 14 passat tdi 70k miles. Last august vw replaced my heatercore due to it failed in the winter. Worked fine when i checked it and decided over the next several months to run the heat a littke just to circulate the fluid sitting in the heater core. Whent to check it and it blows cold air out of the passenger side hot on the drivers side and warm in the middle vents. Would this be a heater core issue or a blend door actuator motor.
Thanks for any input.
Mark Kraft
Mark Kraft
