stancho
I keep breaking things with my torque wrench . A few weeks ago I broke a tranny pan bolt, while torquing it to 9 ft/lbs.
This weekend I was upgrading my injector nozzles to .184mm ones and everything was good until I began installing the injectors back on the engine.
I did install three of them with no problem and torqued the holder bolts to 20 ft/lbs. The last one of them however, kept turning and luckily I stopped in time and only ended up with a stretched bolt. A broken bolt stuck in the head would've been worse.
I got a new bolt from Ace and began tightening it again. I was doing that very carefully now, increasing the torque a little bit at a time. As soon as I got to 15 ft/lbs I heard a pop - turns out the injector holder snapped in two.
The dealers around me don't stock the part, however, I should be able to get it tomorrow. Should I be looking for a new torque wrench or just hope for better luck? Is there something else that I could be doing wrong?
