VCDS, RPM Question....
towforce
West Coast, Canada
Jetta Wagon, 2005, Red
Curious,
When using the VCDS and monitoring cam and crank sensors on my 05 BEW, while cranking... is it normal for the RPM data to go blank (no data displayed)?
Diagnosing a warm start issue and noted that the data fields go blank then display the correct rpm after the start has occurred.
Martin
