ninedee_golf_tdi
Highest piston: .89mm - .0350"
Lowest piston: .81mm - .0320"
Difference: .08mm - .0030"
If I cut .11mm - .004" from the block, I can reach about .92mm for the lowest piston and yet keep the highest piston below the 1 hole head gasket range of .91mm - 1.00mm.
The question is, is it really worth the compression increase to cut a lousy .11mm - .004" to get the lowest pistons (2) within spec ?
For the curious, I have no idea why there are different piston heights. The rods were measured before installation, and the ceramic coated pistons are new.
