As I stated, over 71k miles with the set-up without any problems.
My Turbo set-up (this is an ALH in a Vanagon) was clean as a whistle from the exit of the Turbo pipe to the Intake, including the Intake......But, almost from day one, it has had some oil on the inside.
This last 11,600 mile road trip pulling a popup camper and hauling four adults is the only time it's taken over a half qt (almost a whole quart) of oil to keep it topped off. The engine handled the load extremely well (Ky to Alaska back down thru the edge of the Rockies to Glacier, Yellowstone, Grand Tetons, Rushmore, Badlands, and home (also drove to the Arctic Circle) ...... did roughly that same trip two years ago.
Before the last trip, I installed a new clutch and my original modded tranny ....... I never saw any indication that the rear seal was leaking, nor the front seal. In fact, my engine is quite clean!
I sort of doubt that the majority of the CCV venting is from the Vacuum pump discharge. I have a Vacuum gauge on the vacuum system. It stays at about 23 inches until I touch the brake pedal...... very seldom drops below 20 inches and rebounds fairly quick. As for the Turbo actuator use of vacuum, I have never been able to notice a change in the vacuum gauge while going thru the gears and observing the Turbo gauge to assure it is operating.
All internal combustion engines have blow-by.... high mileage engines will have more. The Blow-by oil mist in the first generation of VW Diesels was horrible, turbo or non-turbo. The engine oil turns black because soot has ben blown by the rings.
I doubt there would be any blow-by pressure going by the Intake valve guides because of the counter pressure of the Turbo. At idle, the blow-by pressure is going to be quite low. The Intake suction on the CCV system on the OE set-up would be more than adequate to handle blow-by at idle rpms, thus no problems with the Intake valve guides and seals. There might be exhaust pressure go up by the valve stems and past the seal on the exhaust valves... However, I've never seen that to be an issue of major proportions!
Side note: Every VNT15 I've disassembled had gap rings for seals. I'd like to know a source for "gapless" ring seals.
