David@OttoStadt
Thought you guys might enjoy seeing this;
http://youtu.be/Hib2dQST5ZE
1962 Unimog military truck with a ALH VE TDI swap that I just finished redoing the engine wiring harness in, the previous shop that had done the harness had done a one off that couldn't be diagnosed easily (and had numerous issues since day one - flashing oil light, 10sec starts, etc..), I just redid the harness and mimicked the exact VW system so that any tech could diagnose an issue on the car with a VW diagram.
http://youtu.be/wbXmKnkh8rk
I'm also working on a plug and play engine harness for any TDI (or VW gas for that matter) swaps in any application, essentially you'll get a box, put ignition, constant 12v, ground and it will fire right up... The Unimog is version 1.0 of this product. Concept;
https://www.youtube.com/watch?v=6K6doYFSR_s
