Bought this car cheap with a non working 01m. VCDS came today.
Friday,18,August,2017,16:11:23:49300
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
Mileage: 211580km-131469mi Repair Order:
Chassis Type: 1C - VW New Beetle (1998 > 2010)
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
Mileage: 211580km-131469miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 N
Component: 1,9l R4 EDC G000AG 2509
Coding: 00001
Shop #: WSC 00066
VCID: 1B60DFEFBAB9C99FAE8-4B1E
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 HK
Component: AG4 Getriebe 01M 4606
Coding: 00000
Shop #: WSC 00000
VCID: 005A8883331F0A475BA-0962
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 00066
VCID: 3E26367B096BBCB7696-4AE0
2 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
35-00 - -
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
Part No: 6Q0 909 605 A
Component: 06 AIRBAG VW5 0003
Coding: 12342
Shop #: WSC 00066
VCID: 353429573C5D7FEFB8C-4B3C
Address 17: Instruments Labels: 1C0-920-xx0.lbl
Part No: 1C0 920 901 B
Component: KOMBI+WEGFAHRS. M73 V02
Coding: 03202
Shop #: WSC 02635
Subsystem 1 - Part No: Ident
Component: Nr. Wegfahrs.:VWZ5Z0X7061378
Ident.-Nr. Wegfahrs.:VWZ5Z0X7061378
Part No: 6N0 909 901
Component: Gateway K<->CAN V022
Coding: 00007
Shop #: WSC 00066
VCID: 70BAD84303BF1AC7ABA-4B1E
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 5X Zentral-SG Komf. 0001
Coding: 00256
Shop #: WSC 00066
VCID: 06569E9B113B2477616-4B00
Subsystem 1 - Part No: 1J2959802C
Component: 5X Tõrsteuerger. FS0002F
Subsystem 2 - Part No: 1J2959801D
Component: 5X Tõrsteuerger. BF0002r
9 Faults Found:
00945 - Crash Sensor (G190)
29-00 - Short to Ground
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01134 - Alarm Horn (H12)
01131 - Control Circuit for Turn Signals
01331 - Door Control Module; Driver Side (J386)
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
01332 - Door Control Module; Passenger Side (J387)
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 180 E
Component: RADIO 3CP 0001
Coding: 00403
Shop #: WSC 00066
VCID: 1A6EDAEBB583B097B5E-4B1E
2 Faults Found:
00856 - Radio Antenna
36-00 - Open Circuit
00852 - Loudspeaker(s); Front
End----(Elapsed Time: 03:28, VBatt start/end: 10.8V/11.0V. VIgn 10.9V)-----
When I bought the car it went into reverse. No forward gears. Messing with it again today when vcds show up, nothing in any gear.
My question is since no codes, can this thing just be low on fluid? I will check it this weekend, but if I were to find the level good, can something else be wrong with the trans that wouldn't set any codes?
The guy I bought it from said it was his daughter's car. She parked it and the next day the trans didn't work, then it sat for 14 months before I bought it. If that story is true, (and I think it is) low fluid seems unlikely. Sounds electrical to me, but seems like that should throw a code.
And before anyone says it, I already know these transmissions suck. A 5 speed swap someday maybe. Would like to see if I can get this thing working for a while.
Thanks for any help!!
www.Ross-Tech.com
Coding: 00001
Shop #: WSC 00066
Coding: 00000
Shop #: WSC 00000
Coding: 03504
Shop #: WSC 00066
2 Faults Found:
35-00 - -
Coding: 12342
Shop #: WSC 00066
Coding: 03202
Shop #: WSC 02635
Coding: 00007
Shop #: WSC 00066
Coding: 00256
Shop #: WSC 00066
9 Faults Found:
35-00 - -
Coding: 00403
Shop #: WSC 00066
2 Faults Found:
