amrrashad
Hi guys,
Have an interesting issue at hand here and need some input from the experts.
My car is an 04 PD Jetta with 267K miles on it. All stock. 5 speed.
New turbo @ 160K and maintenance is up to date.
Symptoms:
On a cold start, if I try to drive the car right away, it runs rough and shudders. If I continue driving normally (shifting around 2,500 rpm), it runs really rough and sounds like it runs on 3 cylinders.
To fix that, I have 2 options:
1. Drive very gently and nurse it until the engine warms up to normal operating temps (nursing here means I accelerate gently and shift early, around 2K rpm)
2. Shut it off, remove the key and leave it off for 2 - 3 mins, then start again.
I keep doing this until the engine warms up to normal temps, then it drives with no issues at all.
If I try to drive it when it's on 3 cylinders, check engine light (CEL) will come on and it'll throw codes (more details below)
Up until last week, this cold start issue is the only issue I had. Once the engine temp was up to normal, it ran beautifully.
Last week, it started doing something else in addition to the cold start issue; while driving normally (engine at normal operating temps), the car would simply die. Just turn off. It doesn't matter what I'm doing, it happened while I was accelerating, sitting in traffic, or cruising on the highway. It just dies. The only common thing I noticed when it dies is that it's usually hot outside or I'd be sitting in traffic so there's some stress.
Once it dies, I have to let it sit until it cools down, then I can restart it again with no issues at all. If it sits for too long and the engine temp drops, then I have to go through the cold start issues detailed above.
If it dies, and I try restarting it before it cools down, I'll get the flashing Glow Plug light along with the same codes as the cold start issues (codes are highlighted below). The car would crank, but wouldn't start.
Codes:
Using Torque, the codes I get in both occasions are:
- P0203 - Powertrain Injector circuit - Cylinder #3
- P0674 - Powertrain
- P0727 - Engine Speed Input Circuit No Signal
If I drive it gently, nurse it up to normal temps and have an easy drive where it's cool outside, the car will run with no issues and the CEL will eventually turn off (the codes will remain stored though). Once I have any of the issues above (cold start or dies), CEL will come back on and I'll get these same codes.
Searching the forums, I found that there could be multiple remedies for these codes:
P0203: Open valve cover and clean wire to injector
P0727: check wires to cam & crank sensors
I've already replaced the Glow Plug harness. Wasn't sure about it, but I wanted to eliminate it as it sounded like it could cause many issues.
This weekend, I intend to:
Do the 2 things to remedy P0203 & P0727 as well as test the resistance on the glow plugs using the excellent Glow Plug 101 thread
I know the lift pump in the tank is good, as I just replaced it a couple of months ago and can hear it buzzing every time I turn on the ignition.
To my mind, the biggest suspect is the second fuel pump, under the hood. That issue where it does when it's running hot then runs fine when it cools down is a classical fuel pump issue (in gas cars) when the pump is on it's last legs. This being a pump that's original has me suspecting it.
What do you guys think? Any other ideas on what might be wrong?
Thank you for reading and sorry for the long write-up. Just trying to be thorough.
P.S: I found this link to a very nice PDF document that explains how the PD engine works. Don't recall seeing it in the stickies, but I found it beneficial in understanding how the engine works and is fueled.
Symptoms:
Codes:
